- clicking brake
- what is this and what fluid do i use?
- Trans Output shaft Brass bushing?
- Bilstein 5100 Adjustable Tundra/4runner
- Need emblem help
- Trouble shooting help (99-00 LImited 4runner t-case)
- Removing EGR valve from EGR pipe - 1999 3VZ-FE
- Steering extension question, body lift
- new plugs and wires, now 4Runner stay on!..
- Minor Updates to 4Runner.
- PCV valve cleaning
- Blown CV Joint Boots (Again!)
- 3rd gen 4runner fuel tank?
- '98 Tacoma wheel size
- Need advice : my theory on gradual coolant loss problem
- which external cooler would be better?? narrowing it down
- Quick Hawk LTS brake pad question.
- Finally got it back!
- Do it yourself gearing/locker install help
- Rusty trailer hitch, could it fail?
- Driver's door won't open from the inside
- What 4runner/Taco have 410 e-Lockers?
- anyone else remove their carpeting???
- a massive high output alternator and two batteries...in my 4runner (pics)
- P0120
- Supercharger Rebuild
- just a few pics from my easter weekend
- 96 taco ext cab safari rack options
- e3 spark plugs in the 3.4L
- Replacing 1999 5VZ-FE Mass Air Flow Sensor - Denso or is aftermarket ok?
- inner and outer wheel seals!
- speedometer is weird on '04 Taco compared to GPS
- Shop recommendation for Alignment in SoCal
- Wiring trailer lights???
- total chaos, camburg, toytec UCA questions
- Ebay "Len" HID & projector retro into 3rd gen 4runner (lots of pics) EPIC
- What fan to use on a Hayden 679 ATF cooler?
- Rock sliders used as step ups?
- Turn signal affecting Cruise Control
- Help with a starting problem - 1998 Tacoma 3.4L
- Driveshaft Slip Yoke Replacement HELP!!!!
- Sway bar endlink tightness
- Need Opinions!! on my emblem job
- Engine Sludge Problem (w/ Pics)
- 98 tacoma 2wd rear spring options
- cel 1135 2001 4runner it's not the MAF
- v6 drinks coolant
- 2001 Tacoma Rough Idle...sometimes
- oem tokico vs trekmaster shocks??
- Another Engine Code P1135 Question
- maintenance advice for my 97 4runner?
- Source for 1999 4runner hood weatherstrip retaining clip ?
- 97 4Runner Rear Diff Lock Dash Light
- Retro-grouch considering "upgrade" from Hilux to Tacoma
- 97 4runner p0305
- So I blew up my front diff... Need to know what to replace it with
- ATF Milkshake survivors ? How long has it been ?
- 2004 auto tranny problem
- 1996 tacoma does this look like a good deal????
- Stretched ABS Sensor Wire, Fix or Replace?
- Water in heater fan under dash passenger side??
- its normal that my camry has more stabilty than my 4runner?
- Sonoran system 3.0
- need help making decisions on some mods??
- My 2000 Tacoma is bucking. Please help me.
- 3rd Gen Auto Trans Drain/Flush/Pan Drop - What do yall do?
- How to prepare for a long summer of driving?
- Rear Diff. Lock with no button??
- Rear tire wear
- Home Brewed Shovel & Axe Mount
- Fuel Gauge
- Sunroof leak -> mildewy headliner
- Clutch Holding instead of Ebrake
- 99 4Runner keeps wasting clutch master cylinders
- LSD Questions
- 99 4runner retrofit pics
- 2002 3.4 tacoma trd 4x4 dies after high revs
- 98 2WD jack location
- need some pages from the fsm 99 4runner limited t-case
- Po172 help!!!!!!
- O2 sensor. Little help here....please
- Filling the void. What to put in the spare tire mount?
- What is ECTS......
- taking rear door panels off
- Belt Replacement 98 tacoma 2.7L
- DIY: Load Leveler Air Bags - 3rd Gen 4runner
- Warn bumper for 2000 4runner???
- help! cv stuck in diff!
- 3rz crank bolt removal
- 99 4Runner SecurityKey and Keyless Entry FOB
- 04 Dbl Taco 4x4 interior light replacement
- Fog lights in the grill?
- Hill descent
- Dead Rig, Need Help!
- Power Antenna Replacement Fail - Antenna just pops out
- Drop in MPG
- Denver area guys want to plan ahead-auto tranny milkshake issue
- Key with Integrated Keyless Entry
- 92 trailer hitch to 99
- Headlight adjustment on a 2000 4runner
- 2002 Limited 4runner - Digital AC Display
- High Output Alternators 3rd Gen T4R
- Uniden 520 XL Install (w/ pics..)
- door locks and gas door lock dont turn
- Headlights
- TJM bumper for 1997 will it fit 2000 Tacoma
- Another Tundra brake question
- My Turbo 3.4 4Runner
- 1997 Tacoma Radiator Core Support Question
- Replacing bushings??
- Key question
- 3rd Gen All Shiny 'n' Clean!
- P0136 code O2 sensor question
- Not a bad deal for $10, hood scoop ;)
- Small Ding and Rust - Fix Myself or Take It In?
- Broken Fog Lights?
- Trail Gear bumper on my 3rd gen 4Runner?
- rear passenger brake doesn't bleed fluid?? 97 4runner 3.4 v6
- idle revs up once in a while 97 4runner 3.4v6
- Programmer or Chips for a 1996 Tacoma
- clutch impossible to push
- With or without KC lights
- rear coolant lines rusted out
- Will old stuff work on new truck?
- Loose brake rotors
- How many skid plates do you have
- Tru-Cool 4454 Install?
- 04 Taco front clear corners
- wich color has the tachometer wire in 4runner 99?
- Reflash of computer neccesary after tranny install??? Ripoff??
- Show me your rear storage/sleeping platform!
- rear axle housing swap from rolled 4runner
- Burning up my clutch
- Flex Plate/Fly Wheel
- Transfer case woes: 99 4Runner
- Transmission Problem (?) on 2000 4Rnr
- Another Tundra TRD lift installed: 2002 4runner!
- Videos of my 98 taco 3.4L
- My Milkshake keeps my Toy in the yard
- 2001 Tacoma Automatic dies when put in drive..help
- Leak! Transmission or Front Diff Breather???
- Check your steering rack bolts :/
- 2001 4Runner ARB Safari Snorkel install (3rd Gen. 4Runner write-up) PICTURES!!!
- Finally did it.. ARB Bumper Install Complete
- Power Seats Installation
- Pulling down the headliner??
- Suggestions for SF Bay Area machine shop
- 231mm bleeding issues?
- Loose Steering on the Interstate
- 4Runner Snorkel install time
- Driveshaft Question?
- Transfer Case 2001 2002 4Runner. Early 3rd gen retrofit.
- Head Gasket/Knock Sensor Problems
- Can you disable the transponder system in a 1999 4runner ?
- Using 2WD trans in 4WD 2001 4Runner??
- 3.4 Engine Design and INFO--NEEDS A STICKY
- Tacoma 3.4 w/ cracked cam
- really bad lean!!! need some insight.
- 3.90s with 35s
- Rough Country Shocks
- Power steering pumped burned out/fried?
- 99 4Runner shakes when i stop for a while...
- Locker engages, but light still flashes!?
- Antenna Help
- 3.4L idling/running rough -please help
- removing the fuel pump
- Just finished steering rack bushings
- Bolt-On Swing Out Complete
- Transmission lines for external cooler?
- 3rz missing on 3 & 4 with random missing also
- First time posting pics of my 4runner...
- California Cats
- P0171 p0302 codes 2001 taco 2.7
- wheel moves left and right?
- Anyone relocate their ECUs?
- Spider Gears
- New wheels and Tires - Severe Tire rub 2000 Tacoma
- do all 99 limited 4wd 4runners have the tall coils? ordering
- Just did the Deckplate Mod...
- 3.4l vibration at 1400 rpm only in neutral or park
- o2 swap
- reseting the ecu with supercharger
- Are all ik22's the same?
- 2001 Taco Fabtech coil over's
- Rusted Exhaust - replacement options
- 4runner exhaust/intake upgrades
- Worked on a 96 4Runner this weekend
- ISR mod, P.S. pressure hose MIA
- How can I remove radio in 98 4Runner?
- 99 4runner fog light wiring
- Airbag light on after install
- Tacoma & 4runner front struts-interchangable?
- Blow Head Gasket TIme for Rebuild
- Cylinder 2 misfire please helppp
- Returning to the scene...pointers on 4 cyl MT 2wd
- 2002 winch plate noob Qs
- Car Topper boat on roof racks?
- 98 4Runner Transmission 4 cycl/ v6
- possibly a pinion bearing...???
- New suspension kit 2002 4runner
- Mass Air Flow Sensor
- 4runner Cylinder Misfire/Miss
- 02 Sensors Error Code 1/2
- 03 Taco wont shift into 4WD
- More than 1 place to modify valve body?
- Rear Window Help - Gremlins!!
- replacing front struts on 2000 tacoma prerunner
- 99 Runner V6-removal of the transmission
- Running Smaller Tires
- random rough idle right after startup
- 2000 Rear Coils and Shock Replacemnet
- 1999 SR5 4x4 5VZ-FE idling low when warmed up
- 3rd Row Seat Installed...
- 4x4 Won't Engage, Light Flashes
- Anyone running Unique 16" wheels from Discount Tire?
- hit and run... my poor bumper!
- CEL light will not go away!!!
- Glove compartment organizer?
- 97 Gas Gauge Issue
- Torque Converter A340F
- Desperatley in need of a pic of a 2.7 taco timing chain/s assembly
- Coolant leak
- Tacoma V-6 milage concerns?
- bent axle shaft!
- Where do I buy flywheel pins?
- Replacing some vacuum hoses - should I go silicon?
- New jack location?
- clarification on 99 4Runner coil springs.
- 4cyl Tach in a 6 cyl truck?
- 99 4Runner heavy front end shake under load
- 4runner Still Shaking/Shimming down the road
- Possible to switch bench for bucket seats??
- 97 4Runner lower ball joints
- injector replacement 98 4runner
- Torque converter seal??
- front mudflap part number
- weird clunking noise from front
- Custom SS exhaust, Magnflow 22"
- Winch Solenoid in Engine Bay?
- help 1999 4runner intermittent problem starting
- Metallic whine in my '99 v6 4Runner
- towing w/ 4.88s
- Built 4Runner...
- Servicing a 2nd Generation TRD Supercharger for 1999 4runner.
- 1997 4runner wont crank
- Porting and polishing Heads.
- time to change timing belt, parts list help please !
- Tacoma Body Lift Woes
- 3.4L 24" Magnaflow - Official Sound (video)
- Top Plate
