1997 4runner wont crank
I just baught a 97 toyota sr5 4runner its automatic 3.4l 4x4
the runner had a bad motor so i baught one from the junk yard swaped it in,cranked it over but nothing happens...i turn the key over no starter,no fuel pump,and no spark, but get this whenn i turn the key over 4 times the stock alarm comes on beeps once and the light stays on, i replaced the relays under the hood,replaced the ecu/computer,replaced the ignition switch and ignition module
what could be the reason why it wont start?
no spark
no fuel
no crank
one thing i did do is jump the starter from the relay and it cranks but no spark or fuel.
no spark
no fuel
no crank
I already did that,Its mind bogling
this is what ive done
-replaced the ecu
-replaced all fuses
-replaced all relays
-checked the ground wires
-unhooked the battery and hooked it back up
-unlocked the car from the outside twice
-replaced the ecu
-replaced all fuses
was the replacement motor also from a 97 with auto?
see where I am going with this?
There are subtle differences between flights of the 3rd gen Runners (96-98) (99-00) (01-02)
I'm no mechanic and not pretending to be. But the possibilities are endless.
Im having trouble with my starter also.. i had my friend hit it while i tried cranking it over, he thought he'd help me by ppoking some wires with a screwdriver.. After i replaced all the fuses he popped, and charged my battery, I finally got Power back to my dash. Now though, whenever i turn it over my battery goes from 13 volts to 4.. Then slowly back up. Any ideas on the Problem???
I swapped the engine in my 97 4runner and had the same issue, no crank, no spark or fuel. There is a large electrical connector behind the glove box that snaps together, and has a lever that pushes the wires together and locks them into place. I forgot to use the lever. Once I figured this out, everthing worked like a charm. Maybe you should check this too.
Keith
Keith
Jun 1, 2021 01:51 PM
sandyota
Feb 4, 2021 11:16 AM
