bent axle shaft!
Old Mar 7, 2010 | 10:09 PM
99 sas runner's Avatar
bent axle shaft!
ive got a 91 runner with a 01 taco rear end with e -locker and i need axle shafts... does any one know if the 88-95 v-6 ones will work?
Old Mar 7, 2010 | 10:22 PM
vital22re's Avatar
totally a bro
the axle shafts are different lengths i believe.
Old Mar 7, 2010 | 10:25 PM
dam, i sold the rear end out of my 99 for like 75 bucks right after i built it. =(
Old Mar 8, 2010 | 06:01 AM
BajaRunner's Avatar
Just curious, where did it bend?
I snapped mine right near the ABS ring... it appears there is a failure point right at the weld to the outer splined section.
Old Mar 8, 2010 | 09:07 AM
i havent got into it to far.mines non abs. do you know what all years fit?
Old Mar 8, 2010 | 09:18 AM
Trail_Banger's Avatar
Check out that Rancho Toyota salvage yard in California. You can find them here:http://www.ranchotoyotatruckparts.com/ and they are a member of this forum. I've gotten little things (jacks, lens covers) and big things (an e-locker) from them and you can't beat their prices.
The shipping was always reasonable too.
Old Mar 8, 2010 | 10:03 AM
150.... seems kinda steep
Old Mar 8, 2010 | 06:24 PM
BajaRunner's Avatar
ABS just has an extra ring on the shaft, the shaft itself is the same otherwise.
Which will fit? I'd contact DeathCougar. He probably has a replacement in hand he can ship down quickly. Its easier IMO than dealing with the idiots at the junkyards. He knows his stuff.
I remember when I broke mine there were quite a few different part #'s. I think it depends on obviously elocked or non, and abs or non.
Old Mar 9, 2010 | 03:34 PM
PhillyGuy086's Avatar
Are the taco shafts and the 4runner shafts the same length? if so i have a set i'll sell you but the shipping would be from new jersey so it'd probably suck. let me know
Old Mar 9, 2010 | 03:36 PM
Fink's Avatar
Hit up Josh (DeathCougar) for sure - if he doesn't have one he can tell you what years will fit, etc...
Fink
Old Mar 10, 2010 | 06:43 PM
maybe i should just get a early 90's v-6 pick-up rear end???
Old Mar 11, 2010 | 07:52 PM
bump.
88sasturbotoy
Jan 30, 2026 01:57 PM
A2theK
Jan 10, 2016 10:18 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
ripp96
Jul 25, 2015 02:32 PM
yourrealdad
Jul 21, 2015 11:13 AM
