Replacing bushings??
Old Mar 23, 2010 | 07:11 PM
wormhole's Avatar
How difficult is it to change the bushings on the lower contorl arm (lower a-arms) and the bushings that hold the front differental up on a 4runner? What all is involved?
I noticed this weekend while putting my skid plate back on that the bushings on the drivers side looked like they've seen better days. Same can be said for the lower ball joint (no leaks or tears in thankfully).
Hopefully, what I'm describing isn't too confusing.
Old Mar 24, 2010 | 12:51 PM
eddieleephd's Avatar
Diff should be easy with a little floor jack it is heavy so you will need the help of the jack, a-frames?????
Old Mar 24, 2010 | 01:25 PM
hross14's Avatar
The Lower Bushings are AAAAAHHHHHHHH FFFFing pain the but.
BUT--i couldnt get it done so i took it to a shop--when i picked them up they pulled a gun on me and told me it cause them to get a divorce ........
If you decide to change them out--mark where your alignment adjusters are and be prepared to pay ~150 for a good ol alignment.
check it though--they are only 166 piece--that is worth it--you will spend more money on shop time--http://www.trademotion.com/partlocator/index.cfm?action=getJointLocator&siteid=214074&cha pter=&sectionids=19,2512&groupid=61005&make=34&mod el=4Runner&year=1999&catalogid=1&displayCatalogid= 0
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
1994toyota
Jul 17, 2015 03:03 AM
andrewtexas123
Jul 14, 2015 04:29 AM
ptb12
Jul 5, 2015 01:49 PM
