Broken Fog Lights?
Old Mar 23, 2010 | 08:48 AM
LemonRage's Avatar
Broken Fog Lights?
Hi all. Both of my fogs lights work, but they are cracked with holes...Am I screwed and just have to buy a new set, or is there a new cover that I can place on them? Looks like the cracked cover says Safety 95. Thanks.
Old Mar 23, 2010 | 08:51 AM
JWaldz's Avatar
pics would be nice... The covers do come off, so you might be able to go to the dealership... cough, excuse me, I mean STEALership.. and have a pair ordered. Can't say they wont try to rape you for them though
Old Mar 23, 2010 | 08:53 AM
okie81's Avatar
Water finally invaded my cracked my old fog lenses and put an end to them
Old Mar 23, 2010 | 10:17 AM
LemonRage's Avatar
Called Toyota
Just called the stealership, he said I was SOL and would have to buy the entire fog lamp! That seems super crazy especially if the lense can be removed! He quoted me at $418/lamp, but www.toyotapartszone.com has it for a lot cheaper. I'm just going to try to see if I can tear them off of a junker. Thanks for the advice!
Old Mar 23, 2010 | 10:31 AM
okie81's Avatar
Check out Yellow & Blue Lighting; them seem to have the best deal on what you're looking for; although you don't need the brackets, switches and wiring, it's still a decent deal.
http://www.yellowandbluelighting.com...3/Default.aspx
Old Mar 23, 2010 | 10:33 AM
SuperSixOne's Avatar
Yea, I had the same issue where the rubber liner in one of my lights decayed and water got it exploding the bulb.... quoted at $400 USD. Got it for free by going through a friend who's a parts supplier. He said they get em for like $100 - 150.
Old Mar 23, 2010 | 12:02 PM
JWaldz's Avatar
check your inbox Lemon.. I'm selling these fogs over in classifieds
Old Mar 23, 2010 | 12:21 PM
eddieleephd's Avatar
if you speak really sweet to the guys and say that you are not paying that price but would do a lot less they may cut you a deal if you are one of those prefer OEM products type of guy in this realm, but I would definitely suggest after market!!!!!
Old Mar 23, 2010 | 03:01 PM
02_Limited's Avatar
Went through 2 sets of those Hella DE's from Yellow and Blue Lighting. They were garbage. Water got in less than a month after installing them and corroded the bulb connectors. For them to work well you need a custom splashguard to keep water from being sprayed directly at it from the tire. I'd just mount some Hella 500's some where. You can get them for like $70 on Amazon and they put out a lot more light than the OEM projector fogs.
Old Mar 23, 2010 | 05:23 PM
Deceptiwave's Avatar
when the first lense cracked on the driver side, I got some 1/4" thick ploy carbonate and made a new flat lense for the light. It worked well, but now the poly is yellowing.
I think when I get sick of them, I will figure out a way to put some 4 inch lights in those slots. Maybe need some PVC tubes to support them though.
AkitaDog
Sep 1, 2015 08:05 AM
ViperTT
Aug 14, 2015 05:27 AM
mr_manny
Jul 31, 2015 10:39 AM
ddg71
Jul 24, 2015 01:24 PM
rushw
Jul 18, 2015 01:46 PM
