- What Can You Pull/Tow with your 3rd Gen. 4Runner
- Engine Stuttering Badly
- Stock rear electronic locker not locking
- A big 'hoorah' to our servicemen
- Which sliders to order from Stubbs?
- ARB question
- Is there a brake job right up
- Will these fit my truck?
- Gauge and dash backlighting
- removing UCA's ...
- Need Help Quick!! Where Is The Flasher Unit?????????????????
- Installing the Airaid MIT / Jr. on your 4Runner or Taco? Consider this...
- New BruceTS Bumper/ CO2 Tank Mount
- Spare Tire
- What is the top taillight??????????????????
- 4x4 light on dash, how to disengage...?
- Anyone have a 5VZFE vacuum hose diagram?
- Power Antenna Toggle?
- Need Help Fast!!!*****
- timing belt and parts online?
- rear bumper ?
- Service Manuals, what do you use?
- OME 880/906 installed 1999 4Runner
- IFS Droop Question
- Did the 3.4L motor change at all?
- longer term head gasket solution 3.4L
- Toying with the the idea of a Toytec Lift.
- Am I getting a good deal?
- 4Runner gets a Engel 45
- Where to buy a SPANNER WRENCH for SAW's?
- replacing axle seals
- RPM help? after changing o2 sensor
- How's the 2.7 for reliability?
- P0305 Fixed
- MT-90 and manual transmission
- Any Good S/C Tuning Threads Out There???
- 3.4 Intake options
- Installing 99 roof console, need help
- Black Rims on a Black 4Runner?
- Hilux Surf Field Monitor unit install
- Help installing my tundra springs
- isr mod
- How to fix this?
- cvlighthouse's 01 TACO TRD (LIFT, CAB OVER, ETC.) *Lots O Pics*
- 3.4 Obd wiring & studdering acceleration help
- How the heck do you get the door panels off on a 2000 limited 4runner???!!! HLEP!
- Hitch and bike rack problems
- VCS and check engine light on?
- Owned by oil change
- Best way to fix rubbing?
- Disabling Running Lights?
- Have an idea, want some opinions
- Tire sive and fuel?
- Break-down/Diagram????
- 97 4Runner with 2.5" lift What Shocks should i get?
- door locks acting up on '00 4runner LTD.
- buying a used URD Fuel Upgrade Kit
- Radiator empty = Strawberry milkshake Tranny Fluid
- '99+ 4Runner center console cover
- Aren't the dash lights and trailer lights supposed to work??
- Jailbait?
- Transfer case skid plate?
- Is this as good as it sounds?
- 97 4Runner Limited A/C issues
- Anybody need a 1998 Owner's Manual?
- Replacing Stock Stereo
- Sway-Away coilovers - opinions?
- '98 Tacoma TRD - Worn Shocks??
- Traded my Gen 2 for a Gen 3
- Transmission slight shudder when stopping?
- front windshield tint
- Mudguards
- Gas Light Question
- New tires on my 97
- air conditioner is not as cold as it should be
- Capabilities of a stock 4runner
- How to remove crankshaft bolt on AT?
- AC Compressor
- Add a leaf kit?
- 2.7 Idle speed
- Repacking Hubs/Wheel Bearings
- Where did you drill a hole through the firewall for wires?
- Buying a 99 Runner
- Valve Chatter...
- panhard bar?
- Wheel torque specs
- sputtering 2.7
- Lean left bank code?
- SR5 Fender flares
- Engine Problems
- 285/75 BFGoodrich All-Terrains on!
- Finally - Alignment correct
- Rough start and white smoke on occasion
- AC doesn,t work : I need a ?dryer? and a gasket; DIY job?
- rear driveshaft 4x4 measurements 96-00 and 01-02 lenghts
- Another infamous "Will these wheels fit on my 4runner" Thread!
- CBI Frame Reinforcements installed! (m)
- Lift/Stuff Installed!
- Borla drop in muffler
- Where to get 2 EWD'S
- Questions about installing bigger battery and new cables.
- When do tires needs balancing?
- New Clutch Time?
- Tacoma 3.4
- Waiting to lift it??
- My Awesome Brake Job - A Confession
- In search of 3rd gen. 4runner
- Lift dilema, advice please.
- 98 4runner rearend
- ATS Location??
- Clicking/ticking When wheel is cut all the way
- VSC TRAC, TRAC OFF, CHECK ENGINE lights
- Thanks for a great site.
- box behind battery and fusebox
- SS 1.51 lift measurment.
- Getting for lift w/ PICS
- A/C Unit
- Oxygen sensor issues : replacement?
- In need of hardcore wax
- cheap pro-comp coilovers?
- Bought NAPA Wheel Cylinder...its different size than original...is this OK?
- anyone with an Optima own a custom made hold down?
- 4-Runner Stalled
- finally changed the gear oil
- skid plate for a 6 inch fabtech lift
- Need Some Advice, 4runner doesnt float!!
- In the process of bleeding brakes and keep getting bubbles...
- Rear Brake Cylinder Leak...Cannot take off(screw broken) What are my options??
- Engine Cleaning
- SC'd 5VZ-FE experiences anybody?
- anybody find replacement cat that doesnt kick p0420?
- Stupid Fog Lights.....
- Help needed - engine noise.
- LC or OME 891?
- topout spacers.
- Where can i put the tranny temp sender on a 2000 4runner v6??
- 3.4 water pump + timing belt question
- 2000 Tacoma
- rims and tires
- rear axle hp rating,
- LED light bar?
- good deal or not ?
- Deck Plate Mod + ISR Removal = Idle Hunt?
- just need to vent. toyotas rule
- How much space should be below the bumpstops?
- Is this a symptom of a starter or solenoid going bad?
- '99 4Runner O2 sensor plug - how the hell do I get to it??
- rear driveshaft zerk broken off. help!
- Rota Grid Interest "TE37 REPLICAS"
- Possible transmission problem or am I finding problems not there?
- Tail light fuse & trailer towing
- Flowmaster & Deep Tone?
- TJM Clear blinkers?
- A Question for the Ages: White or black?
- Steering Rack Replacement
- Sliders as chip protection?
- Warranty
- ac
- Which body lift accessories?
- Where do you put the oil pressure sender in a 3.4 4runner?
- Good deal on stock wheels?
- dual battery inline fuse
- Black Exhaust Pipe, Low mileage, Squealing, Funky Exhaust
- Replacement Radiator and front Skid plate
- Noise in Front end While Turning Left/ Clicking while going straight.
- Toytec Lift Install Time?
- 4Runner locked up after stopping?
- Intake scilencer removal mod
- need 5vzfe pics
- Fabtech lift with sag?
- mod or not
- Finally did it.....Lift and Tires
- My seat squeeks..help!!
- motive power bleeder
- Which shocks to get?
- Front Tundra Coil Question
- Front A/F sensor part #?
- Kevin's Magnaflow video
- Octane???
- california emissions?
- My transfer case is DRY!!! HELP!
- WTB: One '97 LC FZJ-80 wheel center cap.
- Trailer Light Converter
- Need to replace my 3.4, good sources??
- Service & Parts Manuals for 02 4runner
- Anyone with SS #3 lift / 99 suspension / 32's
- 2004 Tacoma spare on a 3rd gen 4runner
- Rancho 5000 Question
- eBay Hi-Lift Legit?
- Land Cruiser rims on mud
- 3rd Gen: Fixin the front!
- '03 Auto Taco, never change ATF ?
- Factory brake question
- 3.4 ltr Oil leak / Seepage
- Anyone Rhino/Herculined the interior of their 3rd gen?
- Lights, lights, so many lights...
- Bed/Topper combo
- 99' 4runner enging ping
- 3rd Gen roll bar install
- Running Hot
- Installing undersized tires
- My new Tacoma
- Is my limited a freak of nature?
- Do You Need Distilled Water For The Coolant?
- ECU doesn't go into Open Loop!
- P1135 Code and VSC lights on???
- 99-02 front bumper
- Idiot Light question
- Transmission shakes stuck in drive after Royal Purple Flush
- installing oil sending unit
- First OME flex shots (with new breather extension hose)
- HELP!!! No windows work
- Adjusted ARB Brackets for Body Lift
- 3rd gen radio install questions
- Where to find window visors that dont have to stick to the outside of the car?
- installing camburg arms, some problems
- installing camburg arms, getting real irritated
- poly steering bushings - my experience and findings
- Most reasonable site for gears?
- Been a while... Here's the progress.
- 03 DB-Cab 4x4 towing
- Should i sell my 96? (not sure if i could pull this off)
- Just Pondering
- Alignment Issues...
- Inspection price fair?
- Sugested Maint at 69k Miles?
- OME 882 Front Lift W/O Bumper
- aux lights and radiator air flow?
- andy mod on a '98 4runner?
- clanking coming from front coil spacer
- Truck wouldn't roll
- I need a pic of a '99 4Runner spare tire crank rod
- Look what you yotatech guys made me do...
- anyone running 18" wheel's or larger on a 3rdgen?
- "Standard" Duel Electrode Spark Plug Life Span?
- LM-1 02 Sensor Cable Routing
- Question about Bilstein shocks.
- Quick Question About Brake TSB on '01 Runner
- ATTN: aftrmkt tranny cooler owners
- Hit and Run!!
- too lean
- Fuse diagram
- Rear Window switch stopped working
- setting up a 4wd to a 2wd in an emergency.
- friday accident
- my new 2000 4runner what kind of service should I have done
- 2001 T4R New Bilstein HDs installed but rear is sagging?
- Picked up a scooped hood, made it functional, Line-X'd it black *pics*
- No start - ?
