clanking coming from front coil spacer
Old May 13, 2007 | 04:28 PM
atl4runner's Avatar
Every time i go over a speedbump or pothole unless im going really slow my front coil spacers will make this really horrible clanking noise and that cant be normal can it or safe?..and i know this is most likely common sense but i just want a reassuring opinion before i go take it to get looked at..do you think it needs tobe tightened
Old May 13, 2007 | 04:53 PM
Fo-runna's Avatar
Are you certain its the spacers? If you installed the diff drop, it's quite possible that it's your skid plates rattling.
Old May 13, 2007 | 05:34 PM
atl4runner's Avatar
its 2wd with no diff drop
Old May 13, 2007 | 05:42 PM
5-spd for life!'s Avatar
I going to say since I am in the same boat it is probably your strut bushings. That is unless you have replaced your struts when you put your spacers on.
Old May 13, 2007 | 05:50 PM
atl4runner's Avatar
no i have not replaced them yet..it just sounds like a loose clank clank
Old May 14, 2007 | 01:38 AM
kevin444's Avatar
Im also getting this minor clank. Its like a minor metal tapping sound u can hear it especially on a washboard type road. I was thinking of replacing those bushings with energy suspension poly ones. But i need to know the dimension of the stock bushing.
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
razorman8669
Jul 12, 2015 12:13 PM
Vargntucson
Jul 4, 2015 12:15 PM
