Clicking/ticking When wheel is cut all the way
Old May 23, 2007 | 07:40 PM
Skrillah's Avatar
I'm having a problem when I turn the wheel all the way to one side or the other, I get this abnormal ticking/clicking sound. Its not real loud, but it is something I've noticed. I got under there and checked the CV boots and I couldn't find anything leaking grease or oil. So I'm not sure what to check or do about this, any ideas?
The truck is a 97 4runner 4x4 with 135k miles.
Thanks guys.
Old May 24, 2007 | 06:54 AM
eric-the-red's Avatar
Often a sign of cv joints starting to go, is it worse in reverse
Old May 24, 2007 | 07:20 PM
Skrillah's Avatar
Nah, its not any worse in any drive. Wouldn't the boots be torn or leaking?
Old May 24, 2007 | 10:34 PM
leonardator's Avatar
is the sound only when you are moving? how bout power steering issues?
Old May 24, 2007 | 11:49 PM
Elton's Avatar
didint you have another thread hmm i think mines makein the same noise
Old May 25, 2007 | 05:35 AM
Skrillah's Avatar
Nah, this is the only thread I've posted about this issue.
It is only when I'm moving, it almost sounds like there is a wheel well plastic piece hitting the tread of the tires.However, I've checked the tire clearance and that doesn't seem to be the source. It sounds like a plastic clicking noise as opposed to a metal on metal noise, if that makes sense. So thats why I'm not sure if its CV joint related but I'm not for sure...
Old May 29, 2007 | 07:50 AM
dallison's Avatar
it sounds like the cv joint. it will not sound like metal scraping. it sounds just like what you are experiencing.
most likely you have either worn out cv joints or a cv boot busted, dried out, or got some dirt/stones into the torn boot and slowly damaged the joint.
sounds like new front axles for you
Old May 30, 2007 | 08:23 PM
Skrillah's Avatar
If it were the axles, wouldn't it be worse in 4x4?
Old Nov 7, 2007 | 09:30 AM
boardstar's Avatar
sorry for digging up an old thread, my truck;s CV has been going for a while (noticed a click while 4x4 in at 1st) im sure its the drivers side CV. Went and checked it, and the boot isnt torn and there seems to be grease in it still.. it will sometimes click while driving.
my question is are there any problems with an OEM part or is there something aftermarket i should look at?
also, uh, what does cv stand for anyways? lol
Old Nov 7, 2007 | 09:40 AM
Skrillah's Avatar
Not sure what CV means...don't really care to know other than it is the front drive axles.
I did end up replacing both of mine. I discovered the noise to be from my boots rubbing against itself, creating the noise. My truck had 137k miles and the original CV's so it was time to get replaced anyway.
I got my replacement part from Autozone for $80 bucks per side with a lifetime warranty on them (and no core charge). The design of the boot is much different so I shouldn't have this problem again.
Old Nov 7, 2007 | 10:16 AM
Rock Slide's Avatar
It stands for - 'Constant Velocity'.
oem aint bad, but you can find cheaper going aftermarket. Lifetime warranties are good too...as long as you are not replacing them every year. (That just gets old.)
Glad to hear you solved your problem.
ty1er
Aug 1, 2015 11:53 PM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
Massmayhem247
Jul 24, 2015 12:07 PM
rushw
Jul 18, 2015 01:46 PM
