Where can i put the tranny temp sender on a 2000 4runner v6??
Ok i know i saw a thread about this not to long ago but i can't find it for anything!
Where can i put the tranny temp sender? Is there an adapter that i can get that will convet the tranny coolent lines to 1/8 ntp thread and back again so i can put a tee in there?
I have a 2000 4runner limited V6. and i can't put it in the stock sender spot as you can't take it out without taking half the tranny apart and even then you can't put a tee on it due to the space. So where and how do i do it???
I just installed a tranny cooloer and it is drained so i want to get this done QUICK. Thanks!
That home depot is what i ended up doing as i was there anyways and i went to see if they might have some fittings that i could use. So i ended up with a big fitting that works quite well.
I was going to delete this thread but there is no option. Thanks for the help though!
