- Shocks Leaking @ 46K
- How to clean gear oil off plastic windows
- Brake Swap info needed!
- Just a 2" Body lift & 285's?
- Rattle behind my dash?
- 3.4 s/c and gas
- DIsconnecting Rav4 driveshaft?
- Replacement 3rd Gen shocks
- pinging with my 2.7 WHY?
- Need some quick help with my fuse box!
- Bad Brake Booster?
- Is this a 4 cylinder or V6 third?
- Valve guide question
- Newbie needs tech help!
- Spark plug stuck?
- yota wont stay running
- what kinda of air feul gauge do i want?
- 03 dcab taco sagging ass
- oil on the spark plugs
- 91 4Runner stalls/won't start while city driving
- the limits of a locked 2WD?
- a perfectly worthless thread, or YAY to me.
- Toyota 3.0 Overheating - what am I missing?
- defective wing window clips
- Engine HELP! (especially N. Colorado people)
- setting tdc
- gear ratio code question
- Stereo speakers to moniter C.B......??
- Moses Lake on Labor Day?
- Wasted an MT/R on the highway yesterday
- 3.4L Head Gasket Service Campaign ending
- Sequoia Brakes
- Timing belt change: 99 4Runner 3.4L
- DRL's on an '01
- check out my new yota
- '85 1st gen 4Runner. - Bench Seat to Split Seat, Bolt in?
- Tips on changing rear leafs?
- Control Arm Bushing Replacement
- Throwing codes 3.0 v6
- Just completed 3.0L Valve Adjustment (long story)
- 4th Gen Plug change interval
- Supercharger: tension pulley plate torque specs
- Changed my rear brakes and.....
- AC works 1.5 hours then quits
- Drove a first gen with a Supra swap this weekend!
- Car Alarms
- Noisy front suspension
- Herculine 3rd Gen
- SuperCharged V8 4Runner Dyno Run!
- 94 Runner OME lift pics
- Break in period...
- Fender Flare Problem???
- New Pics Of My Two Vehicles
- pic of ride height comparison to a stock vehicle
- 3VZ-E Front Main Seal
- Thinking about buying a 86 4x4
- stupid spark plug question
- side window parts?
- I hate WHEEL LOCKS! Horror Story
- replacing ball joints
- Body Lift Question
- electrical issues
- New Sliders installed 22" from the ground to the bottom of the sliders!
- 2002 Taco TRD shock upgrade HELP!
- 2nd gen Diff Drop
- What good is a 2X4 4-Runner?
- axle code
- Remote Mount Turbos
- my new pics
- Anyone have a Factory Service Manual for an '01 4Runner?
- no valve clearance, I am stumped
- someone's pic got into car & driver...
- why do they detune the 4runner's engine?
- Next Level Stage 2 Performance Chip (Tri-Phase Module)
- Shackle Mount Location
- Brake Vibration?
- clunkin noise.
- gutted my interior
- another annoying noise
- TPS help and Throttle Body Removing
- i know this sounds stupid...
- 1st gen headlight/bright switch
- Darn You 4wheelparts Darn You!
- Floor shifter moves?
- I need help spending money!
- NEWBIE Q's: first mods for an 04 taco
- More power at night
- leaf pack length
- Backed into my 4runner this morning (Pic) I hope
- Alternator upgrades??
- Score, I hooked up with a FREEBY today
- New pics after wax, my BMW, my '00 and my '90!
- 400 RPM Idle drop when in Drive and idle variations
- Any tips on removing old pcv rubber gasket?
- Electronic Shift Kit
- 1995 4runner Upgrades
- Power window wiring?
- BG Products & Services
- These Darn Leaks!!!!!
- Intro - Proud new owner of an '01 4Runner
- Adding ABS to my 96 4runner
- I found a few horses in my 3.0 (electric fan)
- Picture of your 96+ taco with 32's!
- Door dings SUCK!
- More Differential drop?
- front makeover
- Anyone change their speedometer gear?
- Ideas for the silencer box removal on a 2nd gen
- Stoopid Crazy Bling
- Swaping Air intake and Battery places - 22RE?
- Loose /leaky front CV to diff
- So I picked up a little road debris today...(pic)
- 15" or 16" wheels? 32's or 33's?
- 22re in oklahoma
- Tire PSI's??
- Motor and Tranny mounts
- body lift and auto tranny shifter
- Painted factory alloys! And tail lights...
- ballancing problem
- Borg/Warner plug wires SUCK!!!
- 4th Gen Rear brakes
- Cross-drilled vs. slotted vs. both
- Brembo Slotted Rotors
- my stock alarm is driving me and the neighbors NUCKING FUTS!
- need help getting 22r started
- Body Lift really necessary if you plan on getting 285/75/16s?
- flatbeds link
- can t-cases be regeared?
- woohoo! I'm on the "cover" of Paragon's site
- Thinking of selling
- Horrible brakes on an 88
- CV joints
- ARB snorkel/Muffler combo--
- Cable Repair?
- Bumper installed!!! Woo,,hooo!! :P
- Messed up again, I think? How do I put the dist back and get proper timing?
- Ford overhead console in toyota???
- another shock question
- Shocks for a stock 98 SR5
- Summer's Bro's axle kits
- I need pics of 84 22r vacuum lines
- Front bumper search
- Help Help Help Quick
- 18" Magnaflow installed
- catback exhaust on 88 p/u
- bumper pictures
- 86-89 bushings??? (yes I searched)
- Need ideas for a rear bumper???
- leaky Rear differential question
- B&M Tacoma 5-speed short shifter kit
- Hey is this lift kit worth it?
- Aftermarket seats and steering wheel options...
- U-joint replacement
- TRD Cat Back
- 3rd gen IFS and paragon black trails
- Good Antenna? and a jammed CD player
- Driving in 4 low
- Bought a factor hitch but
- 4Runner 4Sale...sad to say.
- Name that noise...... tires?
- Experience towing with a 22RE
- Modded my TJM-15....
- Offroader Insurance. HELLLLLLPPPPP!!!!
- What do you think about this lift?
- LC history... (just a fun thing to look at)
- Is this normal?
- Hellwig sway bar installation...
- What is your real world MPG on the 4th Gen 4Runner?
- recovery help
- Opinions
- Lifted 3rd Gen's Please Help!!
- intake+headers+exhaust=loss of torque?
- 2005 Tacoma Rollout Date Announced
- 2005 Tundra with Bigger V8?
- Airbag Light
- can i just swap out 3rds
- daystar lift need help
- jacobs ignitions?
- 2nd Gen 3.0 AS reed Valve?
- Painting stock wheels black?
- Are all 3.0 V6 Exhausts 2" Diameter?
- Cruise control
- Would This Axle Work And Would It Be Worth It?
- Magnaflow
- Help Please with interior lights!
- Gearing Question for a '95 Runner
- eBay Split Second TMC1.1 $120
- 2000 sr5 v6 & 2004 sr5 v6 Headers?
- Drivetrain "Shifting"
- O2 Sensor Shield ?
- Buyback Program?
- 265/75, 275/70, 285/75 - if you got em, post em!
- Performance Friction pads dusting
- Where and which cat to buy?
- 99 Tacoma Supercharger is a plesant surprise...
- help me think this through...
- Anyone Using The Complete All Pro Tacoma
- airbag suspension for 3rd gens (96 secifically)?
- Air Conditioning System Cleaning/Odor Removal
- Hella Relay Problem
- 2005 Tacoma First Drive
- New here, Hello
- PCV system
- got my truck aligned today...
- limit straps on pro comp rear kit
- newbie needs help/engine swap 2nd gen 4runner
- Which 3rd housing is this???
- For those that asked... Rancho w/ BJ spacers...
- TRD limited slip, any thoughts
- ATTN: 4TH gens w/4.0L v6!!!
- Finally installed SAW/OME lift w/ pics!
- Supercharger and Sulfur Questions from Newbie
- ? about the front right axle
- any nice hoods out there for the 02 tacoma
- Grease leaking from front drive shaft, help
- NEED HELP with A/C and Heat not working???
- '04 Taco DCAB caliper bigger than '02?
- WARNING! AutoZone gas cap is crap
- I need help identifying a brake line part please..
- Step by step intructions for retro-fitting 99-02 front bumper on 96-98 4Runner?
- Tie-rod making bell noises (picture) ?
- Cornfed 2.5" installed on OME
- Brake shoe wear indicator
- Where to buy Downey Idler Brace 2nd Gen?
- ??? about A/C
- QUICK Question - Bolt Torque Specs
- Wheelers Offroad....
- spark plugs.. quick question
- What back spacing do I need?
- Muffler
- Blew My Cv 2 Tim Buck 2
- Steering Woes
- How about 4" backspacing on 99 4x4 Taco?
- 22re intake
- Oil Pump leak
- load sensor for brakes?
- Noisy U-Turn
- 22re vs 22ret(engine swap)
- 5 1/4" backspacing work for 96 4x4 with 32x11.5?
- Can someone get me pictures of 3.4 headers
- Heater core question
- ported/polished heads
- Removing front differential
- 1987 4runner has got to go... see sale forum
- 98 tacoma Wrecked
- What offset? +20 or -19? does that seem right?
- 2" or 3" rear springs?
- Hood Scoop POLL.. (Kinda)
- Looking for a working 1993 A/C evaporator!
