86-89 bushings??? (yes I searched)
Old Sep 2, 2004 | 01:09 PM
Plays_with_Toys's Avatar
Hey guys, I was curious what is entailed in replacing the suspension/steering bushings on the 2nd gen pickups/1st gen runners??? What tools are required and what kind of cost I might expect, both doing it myself or through a shop.
Also, what brand/type are good replacements, and is there anything else I should do while I am working down in there? I have 104K miles on the truck.
Thanks!
Old Sep 3, 2004 | 07:11 AM
Ilovemountains's Avatar
bushings?
Hi, yeah I did a little research also for my 88. I changed the sway bar bushings with Prothane and a new set of end links by the same company; I picked everything up at AutoZone for under $30, what a difference in noise. I also found that my lower shock bushings were shot, so I got a new set of shocks thanks to Rancho's lifetime warranty, which made another big difference. The biggest of all was the front end rebuild I just did, I changed out my ball joints, inner and outer tie rods, idler and pitman arms and a new Rancho 5000 stabilizer kit. I was going to look into the A arm bushings but while I had the front end apart I checked them and they are very very tight still with 148,000 miles and my truck is a V6 so its always had extra weight up front. I changed my rear springs out with a set of Downey 2" lifts, which were supposed to be soft riding, I must have done something wrong because they are very stiff and bouncy to me and I have my shocks cranked up rather firm. All in all my truck rides like new again! Hope this helps but your A arm bushings are probably still OK unless its been beat off road, 95% of my miles are highway and back road! Good luck: drink:
Old Sep 3, 2004 | 09:34 AM
scubasteve83's Avatar
Banned for dupe accounts
I think it depends on how deep you want to get into the project. Most of it could be done pretty easily I think.
Old Sep 3, 2004 | 12:34 PM
My truck is really solid, but I have a slight steering wheel shake under braking, and I've had my brakes looked at multiple times with no visible problems. I was going to get some brembo rotors and some nice pads when my dad suggested just getting new bushings.
Old Sep 3, 2004 | 01:29 PM
could be an allignment problem?
glowz825
Jan 25, 2022 09:28 AM
BigHoss_27
Aug 19, 2015 12:38 PM
hmmhoyhoy
Aug 12, 2015 10:33 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
andrewtexas123
Jul 23, 2015 11:22 AM
