electrical issues
Old Sep 6, 2004 | 08:24 AM
TURNER's Avatar
electrical issues
im havin an issue with my brake light\turn signals, here it is:
when i apply the brakes, the right turn signal comes on solid
when i use the right signal, it works fine until i press the brakes and then it goes solid again
when i use the left signal, both come signals on like hazards, until i brake, then the right signal goes solid and the left keeps flashing
any ideas as to why this is happening would be awesome, ive posted on a few other forums and no one has really been able to help
thanks
turner
Old Sep 6, 2004 | 08:37 AM
BruceTS's Avatar
Check your ground wires, if that doesn't solve your problem, look for a cut or a pinch in the wiring harness leading back to the bed, the wires could be shorted together. Do you have the stock or aftermarket trailer wiring harness kit? If so disconnect it and see if the problem goes away.
Old Sep 6, 2004 | 09:10 AM
TURNER's Avatar
nah i got the stock harness for a trailer, ill check that and see what i can find, does anyone know where some of the ground wires might be? cause i dont
turner
Old Sep 6, 2004 | 10:50 AM
BruceTS's Avatar
The stock trailer wiring kit uses an control module, if that shorted it could give you problems, they can simply be disconnected to see if it goes away.
Old Sep 6, 2004 | 04:58 PM
TURNER's Avatar
ok so took a few hours today and messed with the trailer wiring and checked all the grounds that i could find....nothin, anyone else got any ideas?
turner
Old Sep 6, 2004 | 06:08 PM
BruceTS's Avatar
Unfortunately those were the most easiest to check, now you'll need a wiring diagram and a meter to start an extensive check.
Old Sep 6, 2004 | 06:43 PM
Sludge's Avatar
Check the bulbs I had a problem like that before . i bet one of the filiments broke and is shorting out against the other one.
Old Sep 7, 2004 | 12:41 PM
TURNER's Avatar
now thats a hell of an idea, if thats all thats wrong with it, im gonna happy and pissed at the same time, thanks man....
turner
Old Sep 7, 2004 | 01:35 PM
Sludge's Avatar
Lets us know if that was the problem.
Old Sep 7, 2004 | 04:25 PM
TURNER's Avatar
nope it sure wasnt, i checked em all, both sides, all the bulbs were good, but i did think of something that i forgot to mention in my first post, this problem has been goin on for about 6 months, the first 2 or 3 months that it was happening, it was intermitent (sp?), and then slowly it started doin it more and more, now it does it all the time and has been for past 2 months or so, hopefully that might help you guys out with ideas for diagnosing the problem
turner
Old Sep 7, 2004 | 08:39 PM
Sludge's Avatar
maybe a relay?
Old Sep 7, 2004 | 09:39 PM
BruceTS's Avatar
Intermittant problems are a PITA, but if it's doing it all the time, very easy to locate. You'll need a wiring diagram and a meter to start checking. Unplug one thing at a time, then check each connection for a open / short. Since it occurs when you apply the brakes, start there. Trace all the wiring on that circuit and unplug what you can so you can narrow down the problem location. Personally it sounds like a few wires are shorted together.
Old Sep 9, 2004 | 01:11 PM
TURNER's Avatar
heres a new twist on this problem, now when the left turn signal is put on, and the brakes are applied, the right arrow still goes solid, but now the left arrow flashes really fast
turner
Old Sep 9, 2004 | 01:18 PM
BeaterToyota's Avatar
turner
Dude, your junk is wrecked.
Just make it a buggy and you won't need any brake lights or turn signals.
You get your tires mounted yet?
Old Sep 9, 2004 | 01:35 PM
TURNER's Avatar
give me you TJ for a DD and i will
turner
Old Sep 10, 2004 | 09:21 AM
Flamedx4's Avatar
Still sounds like a shorted bulb or bulb socket, especially since it started and got continually worse. Corrosion in the sockets can do this. The rapid flash indicates a high amp draw, as in short - not to ground, but to another circuit. I would try one bulb at a time - take it out, clean the socket, test with the bulb out. Go to next one. It could also be the switch assembly in the column, but without the wiring diagram that would be a pain to try to test.
coryc85
Sep 9, 2015 06:24 AM
jjrbus
Jul 27, 2015 11:06 PM
v_man
Jul 23, 2015 04:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
