Grease leaking from front drive shaft, help
Old Aug 31, 2004 | 04:32 PM
Yoter's Avatar
Guest
For quite a while now my front drive shaft has oozed grease from where the shaft splines together. I just keep greasing it up but it sprays it all over down there. Do I need to replace a seal or the entire shaft?
Old Sep 4, 2004 | 07:26 AM
Yoter's Avatar
Guest
Bump?
Old Sep 4, 2004 | 07:29 AM
shiftless89's Avatar
You probably have to much grease in there! the seal is designed to keep dirt out, but not realy to keep grease in! one or at most 2 pumps on the grease gun should suffice, there should only be a thin film on the splines to lubricate them.
Good luck!
Mike
Old Sep 4, 2004 | 07:30 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Are you talking about your CV boots?
http://www.diynet.com/diy/ab_suspens...277530,00.html
Old Sep 4, 2004 | 07:31 AM
Yoter's Avatar
Guest
Good luck!
Mike
thanks
Old Sep 4, 2004 | 07:32 AM
Rick F.'s Avatar
OOPS! DRIVE shaft... Me bad...
Jdgarrison
Oct 1, 2015 05:22 PM
camdenbuck
Jul 7, 2015 07:33 AM
TNRunner88
Jul 1, 2015 08:00 PM
Gamble_STi
Jul 1, 2015 12:51 PM
Mr.Black
Jun 21, 2015 10:17 AM
