- 96 Tacoma 3.4 engine swap cost?
- Rebuilt engine in, spins over and won't start
- Deeper dive on clutch pedal engagement issues
- Transfer case actuator switch
- 1997 sr5 bug shield, cleaning front hood Help lplease
- replacing rear 97 springs with 99 tall springs
- has anyone done onboard air?
- how many valves in a 95 tacoma 2.7 l
- Aftermarket fog lights connected to the factory switch
- 98 4runner leakyfuel filter after change
- Vasinvictor's 3.4 rear mount turbo setup
- 95 Tacoma 4x4 clutch/transmission question
- ****help**** truck sputters when accelerating and ideas
- Dash Lights Coming On, Headlights Going Out?
- 99 4Runner Limited build
- Lift/// 3" SL & 2" BL experience recommendations
- Need 1.5" lift in the front of my '96 Taco
- Fuel Pressure Gauge Banjo Adaptor
- Coolant leak out of old tranny cooler port
- Prado Bumper Questions
- Fan Bracket Assembly, 3.4
- Help - New ARB bumper mounts/brackets
- 2nd Vs 3rd Gen
- Cold start Misfire.
- 1999 4runner limited 4wd power steering problems/slipping
- Rear spring help !!
- 4runner p0420
- 98 3rz-fe troubleshooting odd clicking (timing chain?)
- 1998 Tacoma 3.4 2WD
- 3.4 running like crap
- 99 4runner 2wd...4wd (IFS) conversion..
- 4WD not Working - No Indicator Lights
- 1999 Taco Speedo not working Gear Question Help!!
- 97 4runner acceleration problem
- 1999 Tacoma Engine Swap
- no place for the 30A power fuse under dash
- 15.00 3rd gen key fob
- Which speed sensor?
- Sluggish sunroof
- Speedy's 13WL 231mm Brake Upgrade
- what sensor is this on 3rzfe in Tacoma
- new gears, need help!
- oil leak after greasing drive shaft
- Brother's truck is acting up again...
- What does this melted hose do?
- Get your Tacoma frame checked people!
- 1995 tacoma 2.7 trouble
- front axle comparison
- 3RZ engine slight sputtering at idle and airbox explosions
- misfires
- I've done some homework, so where to buy lift parts?
- 02 4runner problem
- Slight Nick on Camshaft: Concern?
- '96 level lift??
- 3 wheeling in the turns!
- Grinding Noise...
- 95 tacoma 2.7 engine harness connectors
- Fender flare giant yellow clips?
- How to wire in a killswitch?
- Transmission Rebuild Advice
- Another Spark Plug Thread
- Relentless CEL. Multiple misfire
- Interesting PO420 code
- Preventative maintenance questions for a new owner of a 2000 sr5 126k miles
- what year 2.7 3rzfe i can drop in 95 tacoma
- Bent axle?! This girl needs help!
- alternator spike?
- Truck won't start after replacing battery terminals
- First Post!
- advice on rebuilding a 3rzfe 2.7 as im new to rebuilding
- Bilstein 5100's question
- 95 tacoma 2.7 head prob sat for 2 years help
- Aux block oil pressure fitting size
- Is my transmission gone?
- 2.7 Head options
- Input from seasoned Tacoma gurus.
- 95 tacoma 2.7L 4cyl
- Here's a fun bit of What the......
- Installing new shocks
- Throw Out Bearing or Input Shaft Bearing?
- Cracked Coil - Help Please - simple problem turning complex
- 04 6 cyl Tacoma loses pwr
- Rear main seal help for beer.
- 01 tcase actuator
- 3.4 Cam gear bolts wont break loose.
- Clutch Job - Other Things To Replace While The Transmission Is Out?
- oil or transmission fluid leak & shifting prblem 97"tacoma v6
- Chirping steering wheel: what's the cause?
- PO 441 "Evap Emissions Control" flow code. Anyone else running without the EVAP syste
- 3.4 fuel pump issues???
- 2000 4Runner 3rd brake light bulb holder?
- Bolted a set of FJ wheels on a 96 SR5 today
- Head bolt torque
- Coil spacers!
- Name that noise
- Drivers Door wont open from inside or out.
- 97 Lifted Tacoma on 37's. Diff questions with pics
- Lift question?
- louder tranny whine, aluminum flecks...
- Coolant in Oil?
- 1996 SR5 4x4 Block Drain Plug
- Blown 5vzfe, need some advice
- Truck won't start...I'm out of ideas
- 3.4L cracked head in Austin, TX, help!
- 99 4Runner Limited Timing Belt
- Axle Bearing Question
- Smoke from the clutch...Is there permanent damage?
- 3.4 Engine Failure *%^$!#$$$$$$
- Toyota economic loss class action settlement
- OEM Head gaskets or other? Is there an OEM kit available?
- 96-02 roof rack
- How much is my engine worth
- 2004 toyota 4runner transmission dipstick filler tube
- 97 4Runner won't start
- Throttle body operation question
- Coolant and Trany FLuid mixed together...
- failed emission test, P0171
- 01 4Runner Milkshaked 9-11
- Front end collision
- Squeak sound when steering both sides
- transmission slipping, what to do
- Built a low profile 12" sub box.
- Tacoma starts, then immediately dies.....
- Left tail light blinks with right blinker?!
- WTB - 01-02 master cylinder / ABS pump
- Grinding Noise Shortly After Startup
- is the iat and the ect temp sensor mod good together
- First Post-Looking for Advice
- Calling on help of the forum with wire harness part for ADD
- 98 4R Rear Window Power Control Module Issues
- Tacoma 2002 3.4 - Startup (fuel?) Issues
- Tach reading high
- diesel swap
- 96 4runner limited 4wd help?!
- Skid Plate help
- TPS Question
- Clutch Disk Replacement
- Installing Rear Axle
- Water leaking on driver's foot
- 2.7 3RZ-FE misfires, stumbles when warm
- 96 Tacoma 4x4 key won't turn
- UPDATE P1126 cel
- Another flashing 4x4 light on dash
- If the smell don't getcha, then the heat will!
- Electrical O/D in and out
- Need a lot of help with my rear brakes
- 99 tacoma build
- 400k Club
- 2003 Four Runner O2 Sensors - Will Check Engine Light Always Alert You When Bad?
- 99 4Runner engine fire
- 3.4 Turbo Kit
- Coolant Overflow Reservoir 3rd Gen 4Runner Options
- 4x4 is giving me crap...
- Rear Axle Seals Leaking - T4r, just clogged breather?
- Need help!! First 3.4l removal and install?
- how to remove the supeer charger tensioner?
- Sliding Rear Window Latch Broken
- stuck opne injector? any help is welcome
- 5VZ FE Crankcase Breather??
- 2000 T4R SR5 4x4 Cluster Swap Tach wire?
- Tacoma storage
- hood latch! not LOL
- Engine Imbalance??
- gears and lockers
- Plast dipped 4runner
- The P0440, P0441, P0446 Trifecta - Need Advice
- 3rz gas guzzler
- Need some help!
- Golight
- Iift for 98 4runner
- 2002 Tacoma no low beams
- 1998 to 1995 tacoma 3RZ-FE swap question
- 01' 4Runner throwing a ton of codes. Need help guys
- 2000 Taco 2.7 Reliability/ New buyer
- 98 or 02 model?
- no oil in oil pan
- What is falling off my car?
- 1996 4Runner wont start - ignition lights on then off
- sluggish at 50mph/gas guggler
- High RPM shift 2nd to 3rd...ALWAYS
- Can't catch a break!
- Simple question about rear axle
- 02 T4R SR5 Differential Breather??
- Clock / Temp Mod
- Specific Cylinder misfire - changes to random misfire
- 4wd-High clunk
- 02 T4R SR5 Mix Air Servomotor NEEDED
- '95.5 2.7 motor swap and other questions
- '01 4Runner High Beam reverse operation
- 2000 Taco Lumpy When Warm
- 2003 Tacoma 4X4 V6 questions
- Battery strap - connected to positive = smoke!
- Replaced 3rd member, now dash lock mismatch :-(
- 3.4L TRD Grey Supercharger Vacc Hose Routing Question
- Supposed Igniter Issue (P1300, any ideas Guys?)
- What seats fit?
- parting another tacoma
- Rough country lift 3" sitting lower in front
- tacoma reg cab gas tank
- Couple of engine rebuild questions.
- 2001 4Runner Supercharged w/ Trd 7th injector kit dyno
- 4wd conversion build *Pic heavy eventually*
- 2004 SR-5 access cab bed size ?
- 4WD Not Working - 2000 4Runner 5spd
- '96 2.4 fuel filter relocation
- tjm bumper help
- 2002 4Runner SR5 no heat??
- Torque app not connecting 2001 Taco
- Crazy high-speed shake in stering wheel, help!
- Rear center seat belt latch?
- 99 4runner clutch fan
- Custom Power Steering Hose Build
- California Emission ??
- 96 4Runner vibration
- I need a broken VNT turbo actuator for the 3.0
- 2001 Tacoma Engine Questions
- sonoran steel taco front bumper on 4runner
- 01 5vzfe cylinder misfire
- AC belt tensioner/adjustment bolt broke?
- HELP!! 98 4runner hesitation/lag when accelerating
- are adjustments needed for inner gears of rear diff after replacement?
- JB Weld vs Bedliner to seal and protect rear diff housing?
- best way to clean replacement rear diff and housing before install?
- 98 3.4 overheat, strange, head gasket? help!
- 2000 4Runner Rust Problem
- 2000 4Runner Trans Fluid Drain/Fill - Hesitation
- Front and rear locker ?
- 1st Gen Taco tranny noise and Clutch advise
- fuel and vacuum routing
- 1998 4Runner Rear Window Mystery... Please Help
- Random Misfire
- fuel pump has power but truck won't run unless pump hotwired
- 4Runner dash light part numbers
- guys running LC coils, drive line rubbing on gas tank skid?
- Do I need to replace my CV boots or axles?
- Need help diagnosing lower control arm issue (Pictures)
- Can't get the Clutch Master Cylinder Bled !!!
- OME 881's (Question regarding top spacer) Worried about full droop
- Installing 883's up front with no sprign compressors, can it be done?
- need radiator advice. is size important?
- 3M Paint Defender?
- Hopefully not a red flag
- snow plows for the 4Runner
- abs question for guys with rear disc swap.
- 883 coils temporaily with no weight up front.
- good headlight assmeblies?
- oh heck another transmission question
- Wideband Help
- I have a leak and no clue what these lines are! Pics included
- Oddball Part Location
