hood latch! not LOL
Old Aug 20, 2013 | 03:33 PM
pineapple's Avatar
Smile hood latch! not LOL
Was getting ready to do the 2nd TB, h2o pump and associated pulleys on my wife's '99 ext cab Taco w/ 3.4. A hood that will not release put the brakes on this project. I cut part of the grill away so I could get to the latch and remove three 10mm mounting bolts (had to purchase a 1/4" swivel to reach the top two). Removed the bolts but only gained about 3/4" (barely able to get my fingers in. I can see catch ON THE HOOD and hook on the latch and didn't have any luck poking w/screw driver. I kept running over to my truck (89 ext cab) w/ the hood up (hood latch looks identical) trying to understand how it worked and I sorta do but still no luck releasing. I did "the search" until I came down w/ blurry eyes. Never had this problem w/ my truck which I purchased new.
Any helpful suggestion would be appreciated. thanks
Old Aug 21, 2013 | 03:09 AM
Texas_Ace's Avatar
Did the cable snap? Generally the cable runs to some kind of lever. You want to follow the cable and then pull on whatever it is/was attached to, it will take some force. Should pop open.
Old Aug 21, 2013 | 08:45 AM
JAvendan's Avatar
on my wife's 2000 4runner the cable separated from the handle under the dash.
i simply reattached it.
did you check that???
joel
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
Davebarbier
Nov 3, 2015 03:28 PM
BimmerSage
Sep 17, 2015 11:48 PM
