YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   hood latch! not LOL (https://www.yotatech.com/forums/f2/hood-latch-not-lol-272323/)
pineapple 08-20-2013 03:33 PM
hood latch! not LOL
Was getting ready to do the 2nd TB, h2o pump and associated pulleys on my wife's '99 ext cab Taco w/ 3.4. A hood that will not release put the brakes on this project. I cut part of the grill away so I could get to the latch and remove three 10mm mounting bolts (had to purchase a 1/4" swivel to reach the top two). Removed the bolts but only gained about 3/4" (barely able to get my fingers in. I can see catch ON THE HOOD and hook on the latch and didn't have any luck poking w/screw driver. I kept running over to my truck (89 ext cab) w/ the hood up (hood latch looks identical) trying to understand how it worked and I sorta do but still no luck releasing. I did "the search" until I came down w/ blurry eyes. Never had this problem w/ my truck which I purchased new.
Any helpful suggestion would be appreciated. thanks
Texas_Ace 08-21-2013 03:09 AM
Did the cable snap? Generally the cable runs to some kind of lever. You want to follow the cable and then pull on whatever it is/was attached to, it will take some force. Should pop open.
JAvendan 08-21-2013 08:45 AM
on my wife's 2000 4runner the cable separated from the handle under the dash.
i simply reattached it.
did you check that???
joel
