1999 Taco Speedo not working Gear Question Help!!
Old Oct 15, 2013 | 02:09 PM
kevenburk's Avatar
Hi. New to registering long time reader. Thanks
I have a
1999 Toyota Tacoma DLX 4cyl 2.7 4x4 reg cab Manual 5spd
Tach works fine...Speedometer and odometer do not work.
It has an electric VSS speedo meter. I pulled the gear out and looked stripped, replaced gear with same toyota gear 33403-39365 30:10 I think. same thing does not work. I pulled the vss back out and hooked a drill to the gear just to rule out any cluster problems, speedo needle moved accordingly as drill moved. so i wrapped the gear in electrical tape just to see if the gear would hit reinstalled the vss...speedometer worked good until tape wore down.
I don't know what I need to do from here. the metal worm gear looks good in the transfer case. My transmission and transfer case do look like they have been replaced recently.
Do i need numbers off my transfer case? Any input would help. I look forward to your replies.
Tires are 265/75/15.
Old Oct 17, 2013 | 04:55 PM
kevenburk's Avatar
Can a different transfer case bolt up to a toyota manual transmission...lets say one from a blazer or vehicle of some sort?
Old Oct 17, 2013 | 05:07 PM
Bigblock's Avatar
Can you loosen the bolt holding the sensor,then rotate the sensor in the t/c? Maybe it's made offset to fit several diff size gears. Rotate it until you feel it stop against the worm. Y'all correct me if I'm wrong.
GreenLion
Jun 7, 2021 10:49 AM
shadowbirdie
Jul 1, 2015 05:14 PM
ACZR
Jun 23, 2015 07:55 PM
gog1968
Jun 22, 2015 05:55 AM
streetuner15
Jun 18, 2015 10:59 PM
