Left tail light blinks with right blinker?!
Old Sep 10, 2013 | 01:02 PM
YotasRus's Avatar
I have a 97 4runner sr5 with 180k, I bought the truck a couple months ago, just put a new clutch in and it drives mint!! I'm not so sure what's up with the left tail light tho, all my lights work the way they should except my left tail light blinks when I use my right blinker? I have no idea what to do I've been fiddling with it here and there but no solution and its starting to get under my skin, if you have any ideas please help!!! Thanks.
Old Sep 10, 2013 | 05:10 PM
loos nut's Avatar
turn signal
check ground to that turn signal.does your runner have trailer wiring? I have seen those trailer wiring boxes short out.
Old Sep 10, 2013 | 05:25 PM
YotasRus's Avatar
No trailor, I switched out the left tail light bulb and put it on the right side and now my right tail light blinks with my left blinker. Could it possibly be a faulty bulb? It's a dual filament and it looks in tact.
Old Sep 10, 2013 | 10:02 PM
wyoming9's Avatar
Red face
Not faulty it is the wrong bulb needs to be a signal filament .
that is your problem.
Old Sep 11, 2013 | 11:16 AM
YotasRus's Avatar
If it needs to be single filament then why does the double work the way or should on the other side? It's just that one bulb
Old Sep 11, 2013 | 11:35 AM
YotasRus's Avatar
Old Sep 11, 2013 | 03:20 PM
hilgeg's Avatar
I see the rear turn-signal bulb as a 7440 (http://www.napaonline.com/Catalog/Ca...440_0278138250) which is a single filament.
As a precaution - I think all 4Runners are wired for trailer lights, but the wire loom stops short. You may have a taillight converter "black box" in either your driver or passenger side rear cargo compartment or behind a panel. That can ground out or get pinched. That being said if that were the case then it should affect your front turn signals too I believe.
My two cents - start with the bulb.
Old Sep 19, 2013 | 10:05 AM
mschweizer's Avatar
Did you fix it? What was the final solution?
Old Sep 19, 2013 | 11:20 AM
YotasRus's Avatar
I've been waiting for payday to buy the bulbs and some other parts, I'm gonna try some of the advice givin and will let everyone know, work has me by the nuts so I have no time for my poor yota
Old Sep 20, 2013 | 09:33 AM
YotasRus's Avatar
It's the tail light bulb, my front blinkers work fine?!
Old Sep 23, 2013 | 08:27 PM
clayton707's Avatar
before you buy a bulb you should test it to check if its a wiring problem. get your hands on a volt meter and test the tail light with the blinker on. it probably wont be a clean signal but it should pulse.
trouble shoot before you spend money.
Old Dec 5, 2013 | 09:19 PM
YotasRus's Avatar
I have a single filament for blinkers and dual for tail/brake. I also noticed that the 3rd brake light blinks as well. I checked all bulbs and there good. I'm no wiring expert but I think that's my problem. Any more advice will be appreciated. I've tried looking everywhere for solutions
Sep 4, 2015 09:27 AM
skebe22RTE
Jul 31, 2015 02:03 PM
nonstop
Jul 24, 2015 06:29 PM
sabine
Jul 18, 2015 03:59 PM
Johntom240
7
Jul 13, 2015 12:18 AM
