PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. direct hits spark plug things
  2. 4x4 mode thoughts?
  3. Hella foglight help
  4. Static Charge with key in ignition
  5. make my own rock sliders !!
  6. Calling 99 stock suspension 3rd gens
  7. Random spark knock
  8. Where to find CVs
  9. A Beginner's Thoughts on Body/Suspension Lift and Tires
  10. Possible Purchase of 2002 4Runner
  11. Random Hard Starts
  12. Wheel Spacers???
  13. 34R spec question
  14. Dangerous sounding rattle
  15. Oversize oil filter
  16. Serpentine belts on the 3.4
  17. trouble with front susp.
  18. '96 4 runner P0306 code, help!
  19. noob headlight question
  20. Will my runner pull this?
  21. Looking for '96 4runner Fiberglass Fenders
  22. HELP! My crankshaft pulley is wobbelin
  23. antenna fix for limited-no fender flare removal needed
  24. fan controler?
  25. power steering only works when gas is applied??
  26. coolant seeping out from the front flange of the catalytic converter
  27. help with tranny fluid
  28. Question about tacoma shocks on 4runner
  29. For all of You with TRD Boost Gauges...
  30. herculiner/bedliner, ever seen it on a yota?
  31. Rear bumper ends on 3RG gens
  32. Tundra/OME setup install/question ?
  33. Transfer Case Leak
  34. Body Lift caused 4wd shifter boot to drop down - easy fix?
  35. Throttle response?
  36. Do the OME 891s ride rough?
  37. purchasing scoop hood
  38. What is Burnt smelling Trans fluid?
  39. Foglight Wiring Problem
  40. 99 4wd coils
  41. Milemarker winch on a gen 3 4runner
  42. CEL again. Code P0446.
  43. Replacing Headliner?
  44. Aftermarket wheel locks w/ washers?
  45. 2wd w/ 4wd coils. Ride quality?
  46. 13HR straight drive, prep????
  47. foxfab sliders are on *pics*
  48. vibration question!
  49. dealer installed alarm ignition starter cutoff problems
  50. lowest prices on TJM and spacer lifts???
  51. Good 4Runner mechanic needed in N. Georgia or S. N. Carolina
  52. Catalytic Converter
  53. Cost of a clutch pack - installed?
  54. Brake Help
  55. what is running rich vs running poor
  56. Diagnose this noise please.
  57. Everybody cool with Sonoran steel?
  58. whats it worth
  59. FSM's...97/98...difference?
  60. rear locker usage on snowy roads??
  61. FJZ80 coils?
  62. OME springs with rancho adjustable shocks
  63. Which thermocouple for EGT gauge?
  64. 99 tacoma 4x4 probs
  65. Color of the limited cladding?
  66. 3rd gen comparision of 1in lift pics
  67. Power Antenna Mast- how to get to the antenna assembly
  68. Roof Racks Interchangable?
  69. seized up cam/1998 3.4L
  70. Replacing Spare tire cable
  71. gas tank size on 3rd gen. 1997 4runner
  72. difference in spacer lift or new springs?
  73. Just put in an order with Jason B.
  74. For all u guys w/ manual tranny's
  75. Satoshi grille is on! (pics)
  76. skid plates - who's got em?
  77. grrr... more repair bills
  78. Bought a used third gen. What maintenance should I check for?
  79. Larger gas tank?
  80. Anyone know a cheap place for touch-up paint?
  81. Front Lift Question
  82. Is a 99 4Runner SR5, 3.4, 5 speed 50K mi for $15700 a fair price?
  83. Exhaust Tip Recommendatoin 3rd Generation
  84. Replaced timing belt,marks were perfect,but not now
  85. 3.4L Supercharger Groupbuy from TRDparts4ru.com : please read!
  86. Timing belt broke/tapping noise now.1998 tacoma V6
  87. Got my Hellas on
  88. Supercharger : Place to buy
  89. Cupholder Insert "Mod" 99+ 4Runner
  90. Towing....will my 4R haul my sled?
  91. fin antennas
  92. Can power Antenna be fixed?
  93. tapping noise/1998 tacoma V6
  94. Do California 3rd gens have added emissions crap?
  95. best fuel filter?
  96. New 02 Sport. Need help/suggestions on mods.
  97. 3rd gen headlight removal question
  98. rear axle ?'s
  99. Question for those with 7th Injectors ????
  100. Heater problem : it gets cold when there's no load on the engine
  101. one-way throttle body supercharger valve needed
  102. 22ret transmission swap?
  103. Got another set of wheels/tires today
  104. Help me diagnose "roaring" noise from front driver area
  105. using factory fog light wires in my 01
  106. Blower motor not turning off...
  107. 96 taco smokes when cranked
  108. Deck plate mod + True Flow kit PICS
  109. belt slipping?
  110. daystar lift question
  111. Anniversary Edition 4Runner
  112. timing belt check/change.1998 tacoma V6
  113. orange corner lenses
  114. 2004 Q-Cab TRD feedback appreciated
  115. Supercharger
  116. temporary third seat??
  117. Sonoran Steel/Stubbs Welding hoops on the TJM
  118. Groaning noise under hood
  119. Help Please, What else is there to grease??
  120. wheelers wheels on backorder. replacement suggestions?
  121. FJ80 Wheel rehab for my 3rd generation
  122. random 3rd gen 4runner badges
  123. ---spray on bed liner---
  124. Where to buy FULL poly bushing kit
  125. knock sensors for 22re
  126. Modified TJM T-15 is finally on!
  127. anyone running 285/75/ with no lift?
  128. bilstein 1500 shocks on stock 98 4x4 taco rear end?
  129. vibrating mirror
  130. Looking for wiring diagram for 99 runner
  131. waddaya think it's worth???
  132. FZJ80 Coils installed making Noise
  133. gas gauge
  134. Replacing Factory Hitch with after market
  135. Post clutch return spring install issue
  136. Panhar drop bracket
  137. Installed Boost Gauge - Quick Question>>
  138. How to remove a cupholder on 98
  139. HELP!!! Rear drum removal
  140. Steering wheel off center after alignment
  141. Shifting into 1st
  142. Hella 550's Mounted On 3rd Gens
  143. eBay find! 5spd, SR5, 4x4 with only a few hours left at $6,500
  144. Body Lift questions!
  145. wheel bearing question - 3rd gen part II
  146. Igniter problem in 2002
  147. Can't part with the runner
  148. bilstein 1500 shocks on stock taco rear end?
  149. rear liftgate rattle
  150. Throttle body adjustment
  151. Dim headlight
  152. Help with 2001 T4R 4X4 operation question
  153. tire/wheel fit question???? 1997 4runner
  154. 7th injector vs. urd in my 99 4runner
  155. 99 4Runner 4cyl ok for off roading?
  156. Whistling Noise From Air Vents
  157. New Tires
  158. turn key once wont try to start try secound time it will
  159. Help Suspension Question?????????
  160. Dilemma - Sell the '94 and buy a '99?
  161. How rare is the 4runner 5 speed with E-locker?
  162. Rear Suspension Options
  163. cleaning the inside of the lenses on hellas
  164. Electronic locking rear diff qeustion
  165. Lift Questions
  166. Elbow removal benefical to gas mileage
  167. Towing a boat?
  168. brake size revisited
  169. 3rd Gen BullBar Install w/ Pics
  170. sunroof buzz
  171. Rear suspension OME 890 or 891
  172. Rear seat back rattling, how to tighten catch?
  173. Glovebox adjustment
  174. someone please confirm this information about wheels
  175. immobilizer? '02 Runner starts w/ "plain" key
  176. Tundra Coils Question..97 runner
  177. Replacement Clutch for 98 Taco
  178. Check engine light diagnosis tools?
  179. 2001/2002 E-:Locker Swap Questions
  180. Towing
  181. Boost Gauge Install Question??
  182. Ultimate Lift - Ton of Yotatechers on Tundrasolutions
  183. Aesthetic question for ya guys.
  184. 3.4 swap
  185. just bought 97 4runner need lift advice!
  186. Driving me mad. Help with diagnosis.
  187. Intake Help!
  188. 99 4runner foglights
  189. Totalled my Taco, got an '02 4Runner
  190. 99 4Runner Highlander wheels on a Taco?
  191. Help me piece together a suspension!
  192. Rear brake load sensing valve removal
  193. Gas Mileage - good results?
  194. Tacoma Coilovers on 4runner?
  195. Body Lift Caution
  196. Tacoma safari bar on 99-02 Runner
  197. adjusting the headlight
  198. Low Idle
  199. Do I have autohubs or ADD?
  200. is 16/19 MPG Realistic?
  201. skid control and center diff lock...this happen to anyone?
  202. 03 db-cab tacoma, 3.4L stranger start
  203. Pic of factory 6-spokes painted?
  204. Strut replacement?
  205. 2001 tacoma=33/12.50s?
  206. Does This Look Different?
  207. 99 4runner all disk brake project
  208. Transmission woes
  209. speakers in rear of 3rd generation
  210. My 4Runner suck is snow - why?
  211. Headlight Adjustment Screws
  212. Need To Lift My Yoda....the right way??
  213. E-locker availability question
  214. Looking for Pics of 3rd gens- w/ and w/o running boards
  215. Swapping '98 air box for a '99
  216. 2005 Mods Review!!
  217. Was 70K miles to late to switch to Sythetic Oil
  218. Supercharger Advise
  219. Explain this lift - 4Runner with 6" susp, 3" body
  220. Towing Assistance
  221. Question about truck beds for a '99 Tacoma Ext....
  222. Ignition "locked" while trying to start
  223. Timing Belts, H20 pumps, belts - need home
  224. checking out a 99 4runner for a friend, what to look for?
  225. Front Bumper
  226. Wanting to install fog lights on my 2002.
  227. HVAC controls
  228. front seatbelts wont retract
  229. AT transmission smoother in the cold?
  230. Tundra Coils ON!
  231. accelleration and gas issue for 2000 4runner
  232. speedhut guage switch
  233. Tundra/OME: Downey 3.5 Rear springs
  234. Anyone running Performance Products lift and body lift?
  235. need to install shoulder belt to replace lap belt
  236. How much tranny fluid and weight for a '98?
  237. 99 3.4 hard to start hot
  238. Loved the LOCKRIGHT, but...
  239. Help diagnosing strange noise/issue? (3rd Gen 4Runner)
  240. revtek lift kits
  241. How are the daystar spacers for 2 1/2 inches of lift?
  242. Gas mileage difference from 265's to 285's?
  243. Just finished Timing belt - coolant question
  244. lift help!
  245. "AUTO" window modification
  246. 295 Nitto Terra Grapplers on a 3rd gen
  247. Fuel guage TSB, why my toyota sucks...
  248. got new tires today
  249. E-locker to Manual locker 4runner
  250. Vibration - yes at 65mph!
