34R spec question
Old Feb 24, 2006 | 08:42 AM
xSLICKx's Avatar
34R spec question
In local battery shops I have only been able to find Optima 35/75 and 34/78. The dimentions of the 35 are 9" x 63/4" x 63/4" and the 34 is the same but 1" longer, so 10". Can someone tell me the dimentions of a 34R, the ca and cca, and also tell me what a reasonable price in canadian would be. I have found the 35 for 129$ and the 34 for 149$.
Old Feb 24, 2006 | 08:53 AM
4RunnerFever's Avatar
I don't know the measurements off hand, but do they even make a 35R? Or are you not needed the reverse posts?
Old Feb 24, 2006 | 09:05 AM
waskillywabbit's Avatar
You can find all that information by looking up Optima's battery website on the web.
Old Feb 24, 2006 | 09:12 AM
Super Doody's Avatar
Check this mount out:
http://www.ttora.com/forum/showthread.php?t=28012
Old Feb 24, 2006 | 10:11 AM
xSLICKx's Avatar
By 35 I meant 35/75 and by 34 I meant 34/78. I have no idea if there is a 35R.
Old Feb 24, 2006 | 10:34 AM
xSLICKx's Avatar
I couldn't find info on specific batteries or any specs on the optima site. I could only find info about the different types ie. red, yellow and blue, no part #'s.
Old Feb 24, 2006 | 12:55 PM
midiwall's Avatar
pssssssssssssssssssssssssssst:
http://www.optimabatteries.com/publi...cal_specs.html
Took me 3 seconds with Google, another 2nd to hit the "Skip Intro" button on the home page, then Product Info | Automotive | Starter | Technical Specs.
ymmv
Old Feb 24, 2006 | 04:27 PM
calg3's Avatar
Originally Posted by Super Doody
That mount looks really
Old Feb 24, 2006 | 05:40 PM
Erich_870's Avatar
Does that fit a 3rd gen 4runner? It looks identical to my engine bay.
Erich
Old Feb 25, 2006 | 11:38 AM
midiwall's Avatar
Yes it will, and I just flipped email with them to confirm it.
Mine'll be here next week.
It's a bit $$$ for a battery bracket, but given that I had to hack my stock one to work (which weakened it), and I'm running my red top on two pieces of 1/4" ply that slips, and I drive wiht my right foot and thus have to shift my battery back into position a lot, it's money spent that makes sense.
Old Feb 25, 2006 | 09:48 PM
Erich_870's Avatar
It's a bit $$$ for a battery bracket, but given that I had to hack my stock one to work (which weakened it), and I'm running my red top on two pieces of 1/4" ply that slips, and I drive with my right foot and thus have to shift my battery back into position a lot, it's money spent that makes sense.
Good to know! Thanks for doing the legwork Midi I really like the look of it and as you said, I have wood on top of mine, so getting that out of there and having a cool looking bracket to boot is worth it IMO.
My battery terminals are another issue though. I'll post some pics of what i had to do to fix them on the other Optima 34R thread.
Erich
Old Mar 5, 2006 | 09:51 AM
midiwall's Avatar
And...
I got my bracket yesterday and put it on this morning.
I'm quite happy - my redtop ain't goin' nowhere anymore!
Click for larger pics
Old, old & new, new and new!
(the green cricle in the first pic shows a slice I had made in the original bracket in order for it to sit onto the Optima at all - not really safe)
For reference, this is the ENOffRoad bracket. From a post on the national TTORA board:
Originally Posted by enroffroad
This is the solution for mounting the Optima MODEL 34R batteries in the stock loction of your 95.5 -2004 Toyota Tacoma. The reason behind this mount was so that you could pull out your stock battery, drop-in your optima battery, place the new mount on and tighten the bolts back up.
The main body is made from 16ga cold rolled steel, that has been dimpled to reduce weight, add strength, and a little style. The body is then welded to 1/8" thick side rails and 16ga angle steel to hold the battery from sliding around.
They come raw finished and are available for $36 shipped to the lower 48 states. If interested contact me at enroffroad@cox.net
Quick shipping, great communication, excellent transaction.
bigjstang
Jun 2, 2025 03:56 PM
foampile
Dec 18, 2022 01:29 PM
Blamalam
Mar 12, 2022 07:34 AM
rustym
Aug 7, 2015 10:39 AM
TDonkey
Jul 26, 2015 10:14 AM
