Groaning noise under hood
Old Feb 14, 2006 | 03:22 PM
4RUNN!N's Avatar
With the car on or with the key in the ON position, after a few moments, I hear a groaning noise for about 2 seconds. I hear this everytime I turn on my car.
Old Feb 14, 2006 | 03:27 PM
JamesD's Avatar
Is their an old man stuck under the hood? Could be the EVAP pump or ABS maybe.
James
Old Feb 14, 2006 | 03:33 PM
jeremys73's Avatar
there's some squirrels humpin' under there...
Old Feb 14, 2006 | 08:35 PM
BajaRunner's Avatar
I hear this noise too. Doesn't almost sound like something moving on a conveyer belt or something? It sounds like a moving part of somesort.
I think it will still do it w/o actually turning over the car. If you just turn your key to ACC, will you still hear it?
Old Feb 14, 2006 | 09:55 PM
02SE's Avatar
The ABS pump will pressurize itself when you turn the ignition to ON, after a few seconds.
Or just after the engine starts, if you quickly turn the key from off or Accessory, to cranking the engine.
The sound could be described as a groan.
Old Feb 15, 2006 | 04:28 AM
GSGALLANT's Avatar
From your nickname "02SE", I'm assuming that you have a 2002. What you're describing holds true for the 2001 and 2002 4Runners, but the older 4Runners have a typical vacuum booster for their brakes. The hydraulic brake booster that you're describing is a totally different beast.
Old Feb 15, 2006 | 04:43 AM
MTL_4runner's Avatar
That is probably the EVAP buzzing.....does the same thing on mine and I just ignore it but I think that you can get Toyota to replace the part.
https://www.yotatech.com/forums/f2/buzzing-noise-45575/
Old Feb 15, 2006 | 11:54 AM
02SE's Avatar
Nope, my board name has nothing to do with my 4Runner.
My '97 4Runner has ABS, and the ABS pump does make the sound I described, always has.
Whether it's the same sound as the thread starter is experiencing, I have no idea. I'm just giving him one possible source of the noise he described.
Old Feb 15, 2006 | 01:36 PM
midiwall's Avatar
https://www.yotatech.com/forums/showthread.php?t=45575
Hmmm, yeah but Jamie, the EVAP will buzz with the ignition off as well - he's hearing it only when it's on.
Mine does what he's talking about.. If we're talking about the same source, sounds kinda' sorta' like an electric motor moving a slide - whrrRRZZZZZZZZZZZZZZZZZZZZZZZZZZZZ - and then it's done.
Old Feb 15, 2006 | 02:24 PM
BajaRunner's Avatar
Midiwall is correct - The EVAP thing is different. I have that too. Sounds like there is a bumble bee in my engine.
Exactly: It sounds like an electric motor doing something and then its done...
Old Feb 15, 2006 | 02:31 PM
midiwall's Avatar
btw... to get rid of this (and not have to buy a new canister), just open the gas cap a bit and then close it again.
The sound is coming from pressure in the tank forcing fumes through the canister. When you open the cap, it equalizes the pressure to outside and the wheezing stops.
Old Feb 15, 2006 | 02:46 PM
My bad....you're right.
Mine doesn't do that at all, do you know what that is from?
Old Feb 15, 2006 | 10:58 PM
midiwall's Avatar
Nope.. and I think that's the point of the thread.
Old Feb 16, 2006 | 04:17 AM
I guess I deserved that.
I was hoping someone would enlighten me on that subject.
Bourbonblues
Dec 15, 2017 05:43 PM
4.34runner88
Feb 7, 2016 02:24 AM
YotaPagota
Sep 20, 2015 06:24 PM
Obmi
Sep 16, 2015 02:13 PM
Kreedy1
Sep 8, 2015 06:33 PM
