Supercharger Advise
Old Feb 3, 2006 | 11:49 PM
964runner's Avatar
Supercharger Advise
I have a 1999 4runner and want more power. One of my friends has a 1996 t100 and is selling his supercharger with 20k miles on it. Would I be able to do a swap directly in my 4runner? Also what is the recomended low cost upgrades and is a rebuild neccesary?
Old Feb 4, 2006 | 01:09 AM
midiwall's Avatar
Dunno about the direct swap, what's the engine in the T100? My gut feel is that it's not the same engine/plenum setup - so it's not probable that it's a direct swap.
"Recommend" becomes relative against "low cost". Low cost is something that you'll need to balance against the possibility of burning a hole in a piston. The general recomendation is that you swap in a high flow fuel pump, larger injectors, and you'll need a piggyback box to be able to handle retarding the timing and increasing the fuel flow - figure a ballpark of $600-700, more if you need to pay someone to install it all. You should also do the deckplate mod, but that's about $10 so it's not a huge deal.
20k is just under the halfway point for the recommended 50k rebuild of a 2nd gen S/C. So "in general", you won't _need_ a rebuild.
btw, there's a lot of info here on the forum about what "we" think is required for a S/C setup...
Old Feb 4, 2006 | 07:11 PM
964runner's Avatar
yea the t100 is a 3.4 just like my truck.
Old Feb 4, 2006 | 07:17 PM
northfacer581's Avatar
GET IT!!
im sure info will flood in about fuel mods...and im sure youve seen threads before....
to simplify for you:
its recommended you do some fuel mods, which will cost a little bit. but overall, its an awesome mod that youll love everyday. its the best way to get more power for our 4runners.
i definately think you should get it!
Old Feb 4, 2006 | 07:20 PM
midiwall's Avatar
Originally Posted by northfacer581
GET IT!!
Yeup... Sounds like you're about to become supercharged.
Old Feb 4, 2006 | 08:28 PM
TomCham's Avatar
It's definately worth to supercharge your rig. I am from Hong Kong & have a 2002 Toyota Prado with the same V6 3.4L 5vzfe engine. Bought a brand new s/c'r from trdparts4u at $1899, TRD header at $750, deck plate mod & ISR. Power increase is awesome . I just received the URD fuel upgrade kit & will install it next month. May be I will consider the cam mod as well cuz I don't want to squeeze out more power by using smaller s/c'r pulley. Will somebody do a tech write up here on s/c'r & fuel upgrade kit? This is a wonderful site with loads of tech info & advices. You need some patient to search through all the threads & extract the essences little by little & combine them in a way to suit your need. Thank you yotatech
Old Feb 5, 2006 | 04:27 PM
964runner's Avatar
thanks for the help guys anyone know what i need to get before I pull the supercharger from his truck and put it on mine?
Old Feb 6, 2006 | 05:18 AM
midiwall's Avatar
Originally Posted by 964runner
...anyone know what i need to get before I pull the supercharger from his truck and put it on mine?
Ummm... In terms of just doing the swap? Nothing really, if the engine's the same, then it's all gonna come straight off of one and onto the other.
Don't forget the checkvalve that sits in a vacuum line - it's a white circle. You'll also want a pair of tin snips around - when you pull the intake off of your truck, it's likely that the throttle body intake gasket is "D" shaped, and you'll want to trim that out to be a circle. It'll make sense when you look at it.
The install manual is here. Go through it and it should help.
In terms of other things that you should have ready for your truck before you do this, then yeah... my list above. A Walbro 190 (fuel pump), larger injectors, and a piggyback fuel/timing controller.
Old Mar 1, 2012 | 11:48 AM
lokey86's Avatar
I have a 1998 T-100 4x4 with the 3.4 v6 and my dad has a wrecked truck exact same but his is a 1997 with the supercharger and headers on it and it has been sitting for about 7 years. can i take that super charger off and put it on my 98 with 169k miles on it and what do i need to do the swap
Old Mar 1, 2012 | 06:00 PM
cpizzle42's Avatar
Really??
Old Mar 2, 2012 | 04:06 AM
lokey86's Avatar
i know i can do the swap but some people have told me the engine in my truck wouldnt stand up to the supercharger because of the high mileage and the trans would probably unfold too but some have told me it wouldnt hurt it
Old Mar 2, 2012 | 12:40 PM
cpizzle42's Avatar
Search for atleast 2 hours before posting again
Old Mar 3, 2012 | 12:38 AM
mokai's Avatar
lol
Steven.m.paulk
Jun 7, 2020 10:45 AM
LCE_Performance
Oct 1, 2015 01:03 PM
Project90
Sep 24, 2015 11:40 PM
anniesball
10
Sep 15, 2015 05:41 PM
anniesball
Sep 9, 2015 09:55 AM
