Can power Antenna be fixed?
Old Feb 16, 2006 | 08:03 AM
cancow's Avatar
My power antenna motor seems to work well makes noise for several seconds when i start up, but the antenna does not move. Is this a fixable situation?
Old Feb 16, 2006 | 08:06 AM
jacksonpt's Avatar
Senior Member
yep - just need a new mast. It's a fairly common failure.
Old Feb 16, 2006 | 08:26 AM
Bob_98SR5's Avatar
you have two options:
1) replace the mast like jackson said
2) replace entire unit w/ non-motorized one. look in the tech section for the "tacoma whip" writeup
bob
Old Feb 16, 2006 | 08:36 AM
MTL_4runner's Avatar
Ditto, most likely a broken mast.
You will need to pull the antenna assy to remove the broken part of the mast.
Once you do that you can reinstall the antenna assy, feed in the new mast and you are done.
Old Feb 16, 2006 | 09:39 AM
northernroot's Avatar
how actually do u take it out and fix it all if you were going to do this
Old Feb 16, 2006 | 10:09 AM
You unscrew the inner fenderwell and it gives you access to remove the antenna assy.
Then taking apart the antenna and removing the broken mast is pretty self explanitory once you see it.
Old Feb 16, 2006 | 11:32 AM
Baker 02's Avatar
Mine worked great until i had my Eclipse Deck installed. Now it doesn't even try to come up. I'm gonna have to take it back in. I'm sure that the installers messed it up or forgot it.
Old Feb 16, 2006 | 11:59 AM
bigacuralvr's Avatar
or, you can remove the top nut around your mast on the fender, and turn on the radio. The mast will come out, then put the new one in place, and turn the radio off, and this will pull in the antenna.
Brett
Old Feb 16, 2006 | 01:23 PM
JGM's Avatar
JGM
bob
Option 3 - do nothing. Mine broke. I leave it at about 5". I still get good reception, doesn't cause problems offroad or in the carwash. Getting in there to fix it is a pain and costs money I would rather spend elsewhere. Just wanted to throw that out there.
montanatruck
Feb 26, 2017 07:07 AM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
lfcarrion3
Jul 18, 2015 04:05 PM
mlavery85
Jul 12, 2015 10:33 AM
ptb12
Jul 5, 2015 01:49 PM
