- 98 Taco high idle/rough cold start
- SR5 Limited Rotors Question
- Driver's Side Door Lock Popper
- Need help with Kenwood stereo RF noise
- Scrreeeeech, clickity clickity. Axle bearings or Diff?
- need hep check engine light code p0100 and p1300
- Changed contacts, still wont crank
- Pulsating Idle after cleaning IAC and throttle body, help!!!
- 96 Tacoma check engine
- '99 4runner, 3.4, hesitation / stumbling..
- Fender Flares
- Hoping its the starter contacts
- Who makes a good cat back exhaust for 1997 4runner?
- Brake light problem
- Need some diagnostic help
- New to 4Runners with some questions
- 3link the front of a 98 runner?
- 3.4l loss of gas mileage...
- Fuel Problems ???
- 99 toyota 4runner transfer case problem
- High Idle, Hot Start Problems
- Truck won't run.. P0100, P0110, P0115, P0120
- New here but I need some imput..
- leaking axle seals - e-locker vs non-elocker housings
- 4 Hours to change belts??
- need advise...8 P codes misfire issue
- Time for a brake upgrade, just a few questions
- Electrical Problems?
- Need exact test specs for MAF sensor
- How the 3rd gen should have been and now I want more.
- Will a 2000 3.4L bolt into my 1996 chassis?
- If you ever need to use the factory bottle jack
- 2.7L 3RZ manifold removal
- Another Suspension Thread...sorry
- Need part # for EGR gasket
- Recommendation for Online Parts
- 2000 4Runner dies after revving up
- Some may really hate me muahaha
- Help locating OME 880?
- Need help diagnosing a potential problem
- catalytic convertor security
- Sensitive Brakes 2002 Tacoma - what's normal?
- Making The Switch to AMSOIL...
- Help me diagnose!
- Help!! 96 Tacoma hard start after warmed up
- Wheel and tire question!!
- front end replacement parts suggestions
- starting issues
- heater makes white smoke come out of exhaust
- Adding 2nd fuel filter ahead ?
- 1996 Hilux surf braking issues
- 3,4 Valve shims
- rear door lock trouble 96 4Runner
- Belden vs NGK vs Denso plug wire sets
- 60 degree vent temp on 2003 tacoma
- Tacoma ARB Questions
- 2.7L Taco - Is there an exhaust that sounds good?
- question about gearing and mpg
- Air Lift air spring help!!! HELP
- Need help with a stranded 3rd gen runner
- Mounting M8000 to T15/T17
- I want to lock my keys in my truck.
- Aliens under the dash.
- new upper ball joint won't seat
- How much deeper could my 4Runner have gone with no Snorkel?
- Suspension Vids...
- Drain the gas tank with the fuel pump, 3rd gen 4runner
- Face Lift
- Suggestions for things to change while engine is out (5VZ)
- Just changed my sparkplugs and now-code P0304
- Engine noise goes aware when AC turned on?
- 5vz-fe guts?
- Crank position sensor wires ripped out
- Is this a rear axle seal symptom?
- 95.5 truggy
- 99 4Runner 5VZ just quit
- Help with pulling engine (99 4runner Limited, 4WD, 3.4)
- No start, clicking sound coming from fuse box
- 4runner 3rz 5 speed mileage
- 3rd gen 4runner 3" body lift
- How to remove windshield pillar plastic?
- I am definitely a Noobie...
- Supercharger info needed! Ie this means you Texas ace and alll
- Need longer wheel studs
- 03 Tacoma need help with 02 readings p0136
- 2001 Dbl Cab Taco Frame replacement
- AC not COLD......How much to RE-Charge??
- Transmission issues
- Po441
- Adjust valve clearance myself? 2.7l
- Portable Winch Mod...
- Driver's side door tumbler...
- Miss only present under 1/4 throttle
- Gen 3 front brake vibration Help
- Transfer Case 4Lo Problems. Any ideas?
- A/c
- on fence about 02 runner, known issues?
- Problem with supercharged 3.4 running rich
- Will a 255/85/16 Fit Spare Location??
- Center Console Mod
- Another sleeping platform build! (pics)
- 4runner bogs when warm
- Tie Rod End Questions
- Finally fixing P0325
- Transmission milkshake
- fluctuating idle
- Need help deciding on a part for my 4Runner.
- Need help with 03 Tacoma 2.7
- Supercharger + ISR Mod Owners....LOOK HERE!
- V6 fuel pump in 2.4L tank.
- Transmission Cooler -Isolated or in Series
- Is it worth taking motor apart to clean?
- Cracked head? I'm not so sure
- Help! 98T4R Rear Bilstein coils, lateral rods disconnected on both sides..oops
- metallic rattle when in D and foot on brake
- 2000 trd taco rr diff lock issues
- Toyota Guru Help Needed - Insane Starting Problem
- Rear Blisten F4-BE5-2451-H0 come with rubber grommets?
- 02 4Runner rear axle seal *still* leaking after replacement
- High Auto Transmission Temps
- 97 Tacoma Tranny Issue
- 2.7L engine PCV valve removal
- made a quick custom grill today
- New Rotors Old Pads Cause Vibration?
- 97 3.4 IAC/TPS Problems
- Firestone airbags installed...questions.
- Third Member Source used or rebuilt in SoCal
- zerk fittings 7 or 8 for a 2002 4runner
- A possible solution to leaking axle seals
- 05+ TRD suspension on a 98 taco?
- drivers side door latches are screwing up...
- Motor thats been sitting for awhile
- ECT sensor plug
- Do any one use rotella oil in their 4runner's??
- Radiator/Overheating Problem
- Camber way out?
- Removing a 4ws shift knob with 4wd button?
- 2000 4Runner Stereo Swap
- backspacing and fender flares
- 3rd GEN 4runner (non-elock) axle ends same as 1st/2nd Gen??
- Occasional high idle
- Finally installed 883 and 891 with 305/70R16
- Drilling a hole for room in this paneling?
- 98 Tacoma TRD rear end problems
- Best Manual for 96 4Runner
- Steering Leak?
- ABS light on/off 03 Tacoma
- Factory bumper (Tacoma 03)
- Anyone ever break off the Plastic breathers on the starter? 3rd gen V6
- 3RZ Power Steering Idler Bearing
- Clutch Chatter When Warm
- Loud rattle/rumble noise??
- Master Cylinder Lines Diagram
- Center Console?
- 315k miles on my cat...
- 97 4runner 3.4 Missfire / Trans jump @ highway speed
- New guy here with rookie questions on maintenance
- New brake pads not hitting outside edge of rotor
- 97 Locker question
- Denver Area Steel?
- Recommended grease for inner joint on front axle?
- Tacoma Drive Shaft Center Support bearing.
- Stock/Injen intake mod
- final decision time on sliders
- Rear Differential E-locker question/issue
- Volant Intake
- Upper BJ Snap Ring Not Seating
- OEM glass headlight part number question
- code P0420
- 04 Taco Pass Window Goes Down, Not Up
- testing a fuel sending unit....conflicting info???
- 97 4Runner - Rear End Metal Clanking Noise
- AC gurgle and rattle
- 1999 4Runner NOx levels & intermittent CEL
- Odd Front End Noise ???
- Front 02 sensor reading/ 420B code
- What A/C part is this?
- tacoma rear axles?
- 2RZFE 1997 Tacoma Valve Shim Diameter HELP PLZ
- 1995 Tacoma EFI Fuse Problem
- Thoughts on Building intake for 2.7L 4runner
- Identifying mystery 3rd member
- Early B day present from the gf!
- finally got pics up
- Complete Rear Axle swap with Elocker question
- 95.5 tacoma won't come out of 4x4
- 96 rear end went out, need help, please
- 4WD to a 2WD
- 4th Gen T4R Rear disc brakes on a 3rd Gen T4R
- Heater hose size
- Are there any aftermarket oilpans for the 2.7?
- 3.4l throttle body size?
- DIY - $10 Deckplate How-To
- How to get correct torque when no clearance for torque wrench?
- productive day!
- Hydraulic pulley tensioner isuue
- cam pulley issue
- Stiff 2001 4Runner Suspension
- 10 min coolant flush stuff
- Need help. Weird noise/buzz
- New member
- High Idle Issue
- 2.7 owners check your oilpans for rust
- 278k miles, Should I Buy?
- Quick question regarding MC brakeline routing 4runner
- Anyone have experience with Sky Manf. GMA-Toyota fittings
- Alternator - weird connector
- weird bulge on tach
- Lucas Stop Leak (Oil)
- loud clunk turning wheel while sitting still
- My vents have old foam/cushion coming out! WTH?!?!?!
- Loud auto. transmission rattle, and recent MAJOR leak. Ideas???
- 4x4 problems Front diff actuator??
- Lift is on, new wheels/tires (painted black), something is not right...(pics)
- Upgrade master cylinder after rear disc conversion?
- Spark Plug Blow Out/ Oil in Throttle Body
- Anyone ever bypass the rad to add stop leak?
- Weird temperature problem that I can't diagnose.
- lock-up clutch and supercharger
- Lift is on, only 4yrs later...
- In process of doing 99+ radio bezel mod on 97 4runner. Need some help
- Stutters and doesn't start - Choke issue? Fuel Cleaner?
- BBS's are on! (pics)
- Any Help Would be Appreciated, Truck Hesitating at speed.
- Bacon fat in radiator???
- 98 4runner running rough misfire on cyl 4
- Building up new truck...
- ECT button manual trans
- 97 tacoma motor
- Help Removing Transfer Case on '99 SR5
- Replacing Tie Rods: Leaking Rack??
- BBS RD on 3rd gen 4runner, will they fit??
- Sport hood on finally!
- 97 4runner 4x4 front end grind/rub
- Weird clutch failure - AISIN Find
- rusted through seat mount HELP!!!
- Transmission changes 97-00 4Runner?
- Should I Use Permatex Disc Brake Quiet?
- 4th Gen headlight switch/buzzer mod retrofit ?
- Jerk/Jolt at low speed Braking-Vibration.
- lift options for 01 xtra cab v6 4x4
- Failed smog high HC and OBD would not communicate.
- ello 3rd gens!!
- 1998 2.7 l starting issues
- 2002 tacoma stopped running
- Where to get insert for rear headrests + part #, 1999 4runner
- Need Help On testing Ign. Coil on 2004 2.7l
- track bar question for guys running LC coils
- 96 4/Runner Flex Plate Help
- 2.5" rear spacer and airbag question??
