1996 Hilux surf braking issues
Old Jun 4, 2012 | 05:25 PM
linkster's Avatar
Hey guys, very new here, and needing a bit of help/advice.
I have just taken my hilux for a WOF, and the rear brakes have come back as being out of balance (the foot brake), by 85%, which is loads of course.
I took it to the dealership i work at (mazda) which the mechanics took apart the rear drums, cleaned adjusted and such the shoes, and put back together.
I had it retested and it was still out by 45%, which is still a fail.
The other issue with them is that some times, when I brake for an intersection for example, and come to a stop it will feel as though the brakes have locked on and it is very hard to take off again, as though the hand brake is on.
To stop this i just pump the brake pedal again, and it feels as though they come free, and i carry on.
The WOF inspector believes it may the brake proportioning valve, and i believe the only way to test them is to replace them.
Upon ringing toyota this model does not have one, its all in the brake actuator, so im buggered if i know, any ideas any one?
Its a 1996 RZN185, 2.7 petrol, 5sp, 4x4.
Cheers,
Lincoln
Old Jun 5, 2012 | 07:59 AM
KZN185W's Avatar
check the pistons on the front calipers. some may be stuck.. if that's the case, you'll need to buy the brake caliper kit from toyota.
Old Jun 5, 2012 | 12:00 PM
linkster's Avatar
Cheers, ill check it out, i always thought it had some thing to do with the back brakes, but never thought of the front i guess... Thanks
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
thefishguy77
Jul 30, 2015 10:59 AM
jgwerth
Jul 16, 2015 03:23 PM
cgilley
Jul 15, 2015 03:32 AM
