Old Mar 30, 2016, 10:35 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota 4Runner Exterior Guides
Print Wikipost
How to remove windshield pillar plastic?
Old May 26, 2012 | 01:51 PM
CZ Eddie's Avatar
I need to remove the plastic cover "arms" on either side of the front windshield so I can snake a bluetooth speaker wire behind them.
I tried the drivers side first, but the damn screws holding the plastic in place was on TIGHT!
I somehow managed to end up stripping the screw heads trying to get the screws out.
Any suggestions on how to prevent this (me) knucklehead from doing the same thing to the opposite side?
I used a pretty good fitting phillips tip on my electric hammer drill. Which I needed because my normal 18v screwdriver didn't seem to have the torque I needed.
Old May 27, 2012 | 05:24 AM
jeremy9allen's Avatar
Just make sure you have a really good quality screwdriver/bit. Maybe a hand impact screwdriver with a quality bit.
Those screws can be ridiculously tight.
Old May 27, 2012 | 01:22 PM
drpdmazda's Avatar
arent they 10mm bolts that you can unbolt, or unscrew? i may be mistaken though. You shouldnt need to remove the entire pillar cover to run the bluetooth wire, with a plastic panel tool ($5 at harbor freight) you can get the wire run without removing the pillar cover. Bring it up over the corner closest to the windshield (where most people put their oil stickers, top left) and then gently pull away the rubber door trim, you can hide the wire under the door boot, all the way down to near the kick panel, then fish it across the underdash into the radio housing area. hope that helps, and makes sense.
jason
Old May 28, 2012 | 06:33 PM
jason
That is some good advice actually. I ended up doing that on another 4runner for a remote start antenna.
Old May 28, 2012 | 07:29 PM
Doug18's Avatar
If screws are on their tight I always use one of the bits that you can attach to a ratchet or use a socket small enough to slip the bit in ... that gives you a point to apply direct pressure and a bit more leverage works every time
JNapolitano
Nov 14, 2019 07:46 PM
4x4-runner
Apr 18, 2017 09:08 PM
rusty904
Mar 27, 2017 05:20 PM
Sep 4, 2015 09:27 AM
TDonkey
Jul 26, 2015 10:14 AM
