4runner bogs when warm
Old May 19, 2012 | 04:30 AM
jscout's Avatar
2000 5speed v6 4runner. When I drive for long enough that the engine is completely warm and stop. Then I start it again. It will run normally for 30 seconds then the idle will drop. It will go from 400-900 and keep bouncing. If I drive it will bog and not go over 1500rpm. To get it going I need to rev the engine until it stop bogging and backfiring. Then its good to drive again. Also in second gear when I accelerate hard. From 3000-3200 rpm it will shake like its not getting gas and then be good thorough the rest of the rpms. What's going on?
Old May 21, 2012 | 12:49 PM
ALLDATAdiy INFO's Avatar
FormerVendor
Do you have a check engine light on or flashing?
Old May 21, 2012 | 03:41 PM
cpizzle42's Avatar
If you figure out what CEL codes you have it will help us, help you.
Old May 22, 2012 | 04:00 PM
jscout's Avatar
No codes. I think it's the iac valve. I'm going to clean it out this weekend.
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
tobylab
Jul 12, 2015 12:53 PM
Jonny246
Jul 12, 2015 04:51 AM
Kluch8651
Jul 9, 2015 10:39 AM
