Master Cylinder Lines Diagram
Old May 1, 2012 | 05:36 AM
pfdaxe's Avatar
Hey guys:
Long time since I posted. I recently had a hard brake pedal (felt like when you turn the ignition off and coast and try hitting your brakes). Anyway, I determined after replacing the check valve on the booster that the booster itself was bad. Last night I replaced the booster and the brakes work, but they are still a bit hard to push. Harder than they should be. I did bleed the brakes at all 4 corners but I'm wondering if I connected the lines at the master cylinder in the reverse order?? Dummy me didn't label them. Could this be a cause? Does anyone have a diagram how the lines route? I tried following the lines, but they go into the ABS so it really doesn't tell me anything. I've checked on here and googled with no luck. Any help much appreciated...
Thanks,
Paul
Old May 1, 2012 | 11:12 AM
pfdaxe's Avatar
If someone could pop their hood and let me know where the front and rear brake lines coming from the master cylinder go to, it would be helpful. Maybe even snap a pic and email it to me.
Thanks!
Old May 3, 2012 | 02:52 AM
pfdaxe's Avatar
Almost 100 views and nobody wants to raise their hoods and take a peek? Weak fellas...
ty1er
Aug 1, 2015 11:53 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
TokyoD23
Jul 12, 2015 06:01 AM
87turboPA
Jul 9, 2015 05:58 AM
