Master Cylinder Lines Diagram
Hey guys:
Long time since I posted. I recently had a hard brake pedal (felt like when you turn the ignition off and coast and try hitting your brakes). Anyway, I determined after replacing the check valve on the booster that the booster itself was bad. Last night I replaced the booster and the brakes work, but they are still a bit hard to push. Harder than they should be. I did bleed the brakes at all 4 corners but I'm wondering if I connected the lines at the master cylinder in the reverse order?? Dummy me didn't label them. Could this be a cause? Does anyone have a diagram how the lines route? I tried following the lines, but they go into the ABS so it really doesn't tell me anything. I've checked on here and googled with no luck. Any help much appreciated... Thanks, Paul :think: |
If someone could pop their hood and let me know where the front and rear brake lines coming from the master cylinder go to, it would be helpful. Maybe even snap a pic and email it to me.
Thanks! |
Almost 100 views and nobody wants to raise their hoods and take a peek? Weak fellas... :(
