fluctuating idle
Old May 18, 2012 | 07:19 AM
trucruiser's Avatar
fluctuating idle
So.... I have been working on ressurecting a 97 tacoma with a 3RZ. It has 93k on the ticker. This truck was parked on the wrong side of town and suffered a bullet through the intake plenum and valve cover as well as the wire harness, which melted at the impact point. To this point I have replaced the harness, valve cover, intake and some relays. I can now get the truck to start and run but my main problem right now is the idle fluctuates high to low to high in a continuous cycle. temp does not effect the idle issue, It does it when its cool and warm. The little valve that pushes controls the throtle pushes it in and out. I have checked all the hoses and cleaned the TB but it doesnt help. The coolant is topped off, it has new oil and filter, cap and rotor. I also checked the TPs which seems to be working fine.
What do you think I should try troubleshooting next?
Any help is appreciated. Thanks
Old May 31, 2012 | 09:21 AM
trucruiser's Avatar
Thanks for all the help LOL
Old May 31, 2012 | 09:28 AM
Lycanistic's Avatar
Sticking IAC is my first thought being as you have replaced the damages caused by the gunshot.
Old Jun 1, 2012 | 08:07 AM
trucruiser's Avatar
Thanks Lycan
Cheers
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
