Portable Winch Mod...
Old May 22, 2012 | 12:53 PM
Swede's Avatar
Hi people, so I finally had time to finish my portable winch project today. The final touch was to adapt a set of 20' 1/0 booster cables with a quick disconnect plug on the one end. Now, anyone with a 2" receiver hitch can use the winch. Say you have a line of 4 or so rigs and none with a winch and someone in the middle is stuck. Instead of having to double back to help out (which is often impossible to do) you just have to pack the winch and booster cable to the guy with a receiver hitch and connect to his battery and away you go! Also for me to boost someones battery, all I have to do now is to connect to the dead battery and plug the other end in to either end of my rig (which already has the plugs mounted and accessible) and that's it. Nice thing about the quick connects, you don't have to worry about grounding out the lead because they are not exposed!
Old May 22, 2012 | 02:20 PM
dirtdobberoffroad's Avatar
sweet I am gonna do the same I want to build my bumper high and tight to the body and a receiver on front and rear so all I have to do is plug it in what end I need..
that is sweet!!!!
Old Jul 16, 2012 | 11:02 AM
ellex44's Avatar
That's Great
I love the idea of using the booster cables! Maybe you can help me. I have a 95 4runner v6 3.0 and I am having trouble finding a front receiver. Any ideas? Warn makes one but it only fits the 4 cylinder models apparently. Could you also tell me how you made the pig-tails for the winch to booster set-up? I'm sure it was more than just a splice and twist. Is there a fuse in there?
Old Jul 16, 2012 | 11:23 AM
iselloil's Avatar
Order from amazon.I bought a warn delivered for around $220.00 model 25873 fits up to 1995
Old Jul 16, 2012 | 11:24 AM
Swede's Avatar
Sorry, no idea on where to find one for the 2nd gen... if Warn makes it for the 4 banger I'd guess it wouldn't be that big a deal to modify it to fit if it needs it. Seems weird to me that it wouldn't fit a V-6 equipped Runner. Not sure what you're asking about the cables but on both ends they're soldered onto cable end connectors. The winch end to eyes and the plug end into the quick connectors. I had a breaker set-up on the auxiliary battery but it often overheated so I got rid of it. So basically the winch is wired directly to the aux battery.
Old Jul 16, 2012 | 11:25 AM
iselloil's Avatar
You use a crimping tool, made for that size cable.Then I soldered mine and then heat shrinked any exposed area.Then put them in the holder/socket.
Old Jul 16, 2012 | 11:27 AM
Swede's Avatar
What he said.
Old Jul 16, 2012 | 11:36 AM
waskillywabbit's Avatar
Going to put multiple receivers on my trailer so I can do something like this for getting non running Toyotas onto my trailer. I like the jumper cable idea with the quick connects.
:wabbit2:
Old Jul 16, 2012 | 11:49 AM
ellex44's Avatar
Thanks
You all rock. Thank You!
Old Jul 16, 2012 | 12:36 PM
ellex44's Avatar
2nd batt winch question
I'm new to all this but I want to do it right. So, is a second battery even necessary if all I am doing is running a winch and three 100 watt lights? I'm not planning on doing all-out rock crawling. The winch will be used if I get stuck in mud, sand, or snow.
Old Jul 16, 2012 | 01:47 PM
Swede's Avatar
:wabbit2:
Umm.... "non running Toyotas"??? Not quite sure what you mean
Old Aug 14, 2012 | 08:08 AM
SHAWNB's Avatar
If you dont want to add second battery just get an alternator upgrade that has a higher amp output such as 220-or higher and you wont have to worry.
Old Aug 14, 2012 | 08:15 AM
Resto-noob's Avatar
I happen to have four. This would beat the come along/chain method that I usually employ.
Nice write up.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
