OEM glass headlight part number question
Old Apr 24, 2012 | 08:58 PM
diesel power's Avatar
Hi,
my PS headlight has a crack in it and i need to replace it. I want OEM glass, no aftermarket. i've found 2 part numbers:
81130-35320 - UNIT ASSY, HEADLAMP, RH LENS AND HOUSING
81110-35320 - HEADLAMP ASSY, RH
i know the unit assembly part is included inthe headlamp assembly part, however what does it entail exactly? i just need the glass so can i just buy the unit assy (its less money).
the diagram says the first part number is #3 here:
any help would be appreciated!
thank you
Old Apr 24, 2012 | 09:19 PM
Elton's Avatar
what year is your 4runner ? cause 96-98 headlights are dirt cheap
Old Apr 25, 2012 | 07:38 AM
it's a 2001.
Old Apr 25, 2012 | 08:09 AM
Elton's Avatar
going rate is about 60 bucks for a oem used one if the mounting hardware is good on your headlight you can switch them around
http://www.ebay.com/itm/1999-2002-TO...044d08&vxp=mtr
Old Apr 25, 2012 | 10:14 AM
thanks
Old Apr 25, 2012 | 01:18 PM
can anyone answer my original question. what is the difference between the two part numbers and specifically what is included in : 81130-35320 - UNIT ASSY, HEADLAMP, RH LENS AND HOUSING ?
thanks again
Old Apr 25, 2012 | 01:39 PM
rworegon's Avatar
thanks again
Take a look at this diagram with P/N references:
http://www.utoyot8.com/Picture.aspx?...&ccode=&ppName=
http://www.toyotapartseast.com/Page_...3556,3557,3558
bigjstang
Jun 2, 2025 03:56 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
msane99
Jul 11, 2015 08:08 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
