- Truck won't start; battery OK, alt OK...
- Removng Decals
- 2001 4runner Issue
- Mod advice?
- 02 tacoma bearing question
- Thermostat Gasket Leak?
- ran through a puddle-now the Batterylight comes on..
- 4Runner Now Gone... I had to..
- Synthetic mixed with Dextron III
- help!! bleeder valve is stuck
- 150,000 mile tune-up
- Rough ride with Tokicos.....maybe worn out after 1 year?
- Cap on the rear end of driveshaft
- need a part for shifter
- Radiator hose clamp : rust ???
- instant reply anybody?
- Brembo Rotors Grinding
- 96 taco frame rust issue?
- Underpowered when cold
- Suspension help on my 96 taco?
- Manual Hub Install
- Retro Fit e-locker advice
- 99-02 Bumper fit on 96-98?
- Exhausts? which to buy?
- Broke a sensor... which one is it
- Smallest lift to fit 255/85r16 on '00 4x2 4Runner???
- Changing trans fluid?
- help with part # please
- Rattling noise when accelerating from low gear
- 4Runner makes a funny noise when I turn on the AC
- Hydrogen gas Generator...
- Supercharged ISR mod question
- 4x2 Ride Heigth v. 4x4???
- snapped my brake line today...
- 4runner console lid part #
- Spare fuses, do you carry them?
- some not-so-great pics of my Runner
- 3RZ 2.7L throttle body cleaning questions...
- Is this factory or aftermarket?
- Buy or Make "Gap Guards" for tacoma body lift???
- brakes squeaking
- What do you guys think of this deal?
- another reason why I love my 4runner
- Steering doesn't re-center??
- Rust Stains
- Rear suspension recall dilemma (Bumpstops on the 3rd gen)
- HID lights for my 03
- looking for 03 taco lumber rack
- OEM Keyless entry - power windows
- Tranny fluid filter?
- pics pics pics of my 02 sport
- wheel ?
- 4 lights across stock bumper.
- Front Strut Options
- Weird Electrical Problem
- wilderness sport rack and the spare tire mount
- Frame surface rust
- Help!! Basic questions for rusted exhaust system
- Vibration Problem
- YotaTech 2009 Calendar Submissions
- 3rd Gen 4wd Suspension Questions
- Herculined my interior
- Pics of awesome 4Runners
- Shuddering at stops ?
- Idle problem
- ARB on!!!pics!
- Power Window Panel?
- Tranny temp gauge, pan or manifold?
- header questions
- Just Bought a 96 Taco SX
- Sticky Gas Pedal
- '96 4wd fs in SoCal
- Help with starting problem
- Transmission Operating Temps?
- Driver Footwell Click
- Darty Sloppy Loose Steering
- Awesome 4runner for sale on Craigslist, Southern California
- Fender Flare mudguards
- Misfire, replaced plugs...
- Necessary to remove trans for a motor swap?
- 2.4Liter Compression Test
- First CEL (PO120) @140k got some ???
- anyone use a eye-stud shock mount?
- Probably Spark Plugs?
- What are your boost readings?
- clear corner lense
- Another OME lift. New wheels/tires
- help: exhaust
- Need Help With Tire Size Situation!
- TRD supercharger
- AC Problem
- Headlight glass
- Alignment Question 2000 4runner
- Noise: is it the Dif? Wheel Bearing? U Joint?
- new battery, dead battery
- Problem with Taurus Electric Fan Mod
- i herculined my bumpers this week....pics
- Removing e-locker 3rd?
- Boost gauge instructions
- 33"/12.50R18 Fit 02 4-runn
- Off to the next project........
- 96 Runner- where can I find a volume knob?
- Low fuel indicator going off - with full tank
- How do I swap the auto for a 5spd?
- Aluminum Calipers--What models
- Climate control on a 2000 Limited out! (att: Death Cougar)
- Where to buy a valve kit?
- Interesting Brake issue.
- ???MAS unit??? URD???
- Will 2005+ Tacoma seats drop into a 2001-2004 Taco?
- S/C tuning session in orange county
- '97 4R too loud? engine, muffler?
- installed an amp - lost my lights
- Hitch question?
- will 4th gen rear shocks fit 3rd gen??
- Radiator damage -> Coolant and tranny oil mixed?
- High RPM Sputter - Post for a friend
- Bank 1 sensor 1 = before the cat? 2000 4runner
- 3rd gen headlights
- hood scoop parts
- rear hatch ladder
- coilovers comparison??
- Done with the Runner for a bit
- How much rust is too much rust?
- Water coming into blower housing..
- MAF Sensor Upgrade for a 2.7L?
- its done! (yeah right). lift, rims, tires, retro blah blah blah
- Body lift
- TRD 3.4L Supercharger ECU?
- Help with my wifes 2001 Dbl Cab Suspension.
- Where to buy head gasket?
- What Truck To Buy
- just installed new wheels/tires on my 4runner - couple new pix
- Wheel backspacing question
- **add To Manual Hub Swap**
- Just to quickly confirm : Curt hitch fitment.
- Part Number Lookup Help?
- Shock Options?
- Ride quality on 3rd Gen stock shocks
- Can leaving my 'SRS' warning light unattended to, have caused my CEL to now light up?
- paint or not?
- Rear window, and remote locks not working, after battery dissconnect
- Proper spark plug placment on each plug...
- 97 taco 2wd 2.4L isr
- quick herculiner ?
- Torque Specs?
- Head Gasket Leak??
- 3rd Gen 4Runner fuel pump
- 01 Taco 4dr 3.4L "shimmy" at HW speed
- 99 4Runner V6 smoking on startup?
- Rear tire well rubbing with 285's and Revtek 3" lift
- Online source for OEM Parts???
- 265/75/16 on a stock '97 Limited - any issues?
- Check Engine Light Code P1135 (Air Fuel Sensor)
- Which is which Tranny lines?
- Anyone like these wheels?
- HELP!!! '96 runner?
- coilover spacer lifts
- front and rear bumpers...
- What 3.4L improvments have you done??
- Maybe somthing wrong with VSC????
- Tacoma clunk gone....viberation begins!!!
- Transmission Mount bolt, best tool for the job?
- toyota dealerships
- I have a question about 2wd 4runners....
- How do I get rid of smelly interior?
- PHOTO - All of the 3rd Gen 4Runner front coil heights.
- test driving 01 tacoma, completely stalls out.
- Another HID Bi-xenon Retrofit Install *PICS*
- 1997 4runner - keyless entry/alarm question
- Shock Replacement Time??
- New 99 4Runner!
- Should a buy a 99 Runner for around 3500 ......
- Rim question
- 11k Uoa 1997 3.4
- Caliper Rebuild Questions
- should i make the upgrade to the 3rd gen?
- How do I know if my 99 4Runner has the stock "tall" springs?
- just a kwick vote 33's now or later
- rear window not working from inside...
- Scangauge / timing question
- New truck
- fixed my dash clock (maybe)
- My Alt Alternator Fuse wont stop blowing I need help !!
- Help needed tonight - stuck in 4WD :(
- who has the 5spd and e-locker combo
- Gear Ratio in E-Locker
- URGENT! Should I buy It? SUPERCHARGED
- Bad shake at high speeds with bigger tires
- shifter vibration '01 tacoma
- suspension diagnosis. am i in the ball park?
- upper ball joints
- Who has or is using the Split Second TMC 1.1 Timing Map Controller?
- Rear window and rear wiper dead.
- help....cv leaking after lift install
- water pump
- any ideas for a front grille???
- Crush Sleeve From Hell
- Please help with wheels!!!
- What size tire to run
- Wheel spacers, again....
- If you break a CV on trail, can you drive it home?
- Ideal BS for wheels when wheel spacers aren't desired?
- timing belt/waterpump replacement parts
- You always find cool(er) stuff AFTER you buy your rig!
- Leaking Diff breather?
- Stock Suspension ?
- newb: pics of my 99 4runner
- Relief!!! No More Scoop Envy
- Strange Code combo. anyone seen this?
- rear axle seal gone. i think..
- WTB 02 Stock 4runner rims whole set
- Question about parts??
- Trans fluid leak
- 255/85/16's on crolison's rig :D
- e-Locker retrofit on 3rd Gen
- New Truck
- Check out my Murdrrrrrrrred out G-ride homies
- Slider Installation Price
- Can someone crawl under their truck and let me know the 02 sensor wiring?
- Soon to be Supercharged
- Taurus Electric Fan Report
- Has anyone experienced this?
- Has anyone Experienced this?
- Is this the daytime running light switch? *pic*
- manik bush guard - fitting Q
- ARB Snorkel for 2000 4runner?
- how much hp can be expected by the 5vzfe supercharger with the 7th injector
- What Does Your Windshield Have On It?
- Good rear bumper??
- Body lift on 99, how big can I go...
- Newb Here, pics of my modded 97 sr5 4x4
- Where to get a new hood
- Still need DRL plug location on 99 runner
- pc based scan tool?
- Any members' experience with these LED tailights....
- New Bilsteins in my '00 Runner
- trails in sd area
- 1998 4runner for commuting?
- Straight Front or No Straight Front?
- jba exhaust question
- Running boards removed Looks WAY better!
- 1st Gen supercharger oil change
- CV boot looks FUNKY and got a lil noise...problem? IDEAS!
- looking for pictures of 4runner with 3" BL + 3" Suspension
- FJ Crusier Wheels with Tundra Brake Upgrade??
- ARB tacoma bullbar fitted to a 99 4runner???
- Alarm/radio question
- Question about stock antennae wires *pic*
