Crush Sleeve From Hell
Old Aug 13, 2008 | 06:29 PM
cnmrosko's Avatar
I broke a brand new craftsman 1/2" breaker bar and still have pinion bearing play and no bearing preload...
what now???
Old Aug 13, 2008 | 07:49 PM
jason191918's Avatar
Buy a torque wrench and see how much torque is there. If you go above the torque and still dont have any preload, you need a new crush sleeve.
Old Aug 15, 2008 | 06:44 PM
cnmrosko's Avatar
At $19.00 a pop and another day and a half wait I said screw that idea of throwing away the hard crushing sleeve. I was gonna torque the crap out of it with an impact socket, a 4' pipe and pipe wrench but thanks to a tip from Zuk and some anti-seize I was able to get the crush sleeve to settle down nicely.
I put some anti-seize on the lower 2/3 of the pinion shaft threads and after I got the nut torqued down 2/3 onto the shaft I coated the remaining exposed threads inside of the nut with red lock-tight. It now required a manageable 225 ft lbs.(+ or -) to reach the proper bearing preload.
Old Aug 18, 2008 | 09:13 AM
GSGALLANT's Avatar
For the next time, you should consider getting a solid pinion spacer from MarlinCrawler.com. It won't loosen after a while like a crush sleeve will.
Old Aug 18, 2008 | 09:38 AM
904_runner's Avatar
^ thats what i had put in mine when i had my diff rebuilt and lockright installed.
The guy said the spacer was a pain in the arse, and he had to take crap apart and put togeter with new shims to get the proper pattern. I guess, im not familiar with too much differential lingo! haha
Alexdosdall
Dec 10, 2017 05:48 PM
vikinghug
Jun 14, 2016 08:10 PM
mreagen
Oct 5, 2015 04:27 PM
Toys4parts
Sep 26, 2015 01:56 PM
94toyy
12
Sep 14, 2015 06:18 AM
