Probably Spark Plugs?
Old Aug 28, 2008 | 07:54 PM
sailing_dude's Avatar
Unhappy Probably Spark Plugs?
Hi all! I'm a bit new to the forum, kinda rude to introduce myself with a question, but I've started to have some problems with the good old Runner You know how if you try to accelerate and you are in too high a gear - how the truck kinda lurches until you shift down?? Well that same feeling is coming whenever there is a load on the engine, such as a large hill or accelerating onto the highway. For example, in 5th gear at 60 mph if i'm going up a hill the engine lurches. Could this be spark plugs or the MAF? Or is it a more serious issue like the clutch? The rpms don't jump when this happens. Thanks!
Old Aug 28, 2008 | 08:09 PM
One possibility
~ A couple years ago i tried to take some slack out of my throttle cable, and a few months later i started getting a CEL for Throttle Position Sensor, however the truck didn't drive any differently until just recently.
Old Aug 29, 2008 | 03:40 PM
SoCalPaul's Avatar
4 Cyl or 6 Cyl? What year? Sounds like you are on the right track. Check spark plugs, air filter, look for loose vacuum lines, check MAF, maybe fuel filter? A worn clutch will usually cause the rpms to speed up momentarily but worn or broken damper springs can cause lurching or bucking under load. I would start with the easy stuff first. Another thought, my Mazda 3 would sometimes buck under load & it turned out to be a bad motor mount.
Paul
Old Aug 29, 2008 | 07:05 PM
It is a 6cyl, and with 128,000 miles i really need to give it a tune up, do you think it could be the TPS sensor? What exactly does that do?
Old Aug 29, 2008 | 11:59 PM
SoCalPaul's Avatar
TPS is a Throttle Position Sensor. It detects the position of the throttle for the computer. Just read a post on a Mazda 3 forum where someone had a similar problem. He had a damaged wire from the MAF sensor. If you have any mechanical skills, get a Chilton or Haynes service manual and perform a full tuneup.
Paul
Old Aug 31, 2008 | 06:19 AM
yeah i'm an alldata member so i'm going to plan on spending a few hundred and replacing all tuneup related items. I'll let y'all know how it goes!
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
accuracy
Aug 4, 2015 08:05 PM
defrag4
Jul 31, 2015 10:50 AM
