installed an amp - lost my lights
Old Aug 26, 2008 | 09:37 AM
idodgimus's Avatar
FIXED
ola,
i installed a small amp in my 3rd gen 4Runner last nite, it went without a hitch i thought... but this morning i noticed i've got no exterior lights other than high beam!!!
i'm hoping that its just a fuse but cant get to look at it til later so i'm hoping for some advice and/or troubleshooting info...
cheers
D!
Old Aug 26, 2008 | 09:54 AM
Yukon's Avatar
Howd you wire the amp? Direct to battery or tap into a wire?
Old Aug 26, 2008 | 10:11 AM
idodgimus's Avatar
amp is wired to the battery terminal and grounded to the body under one/at of the seat legs (using the screws that hold the seat in place).
the battery was disconnected/reconnected a couple of times during the install and the keys may or may not have been in the ignition at the time...
i also tried the full-time-accessory-power-mod, but my spade connectors were too small and so it was a very wobbly connection there... maybe that helped?
Old Aug 26, 2008 | 11:00 AM
Yukon's Avatar
Thats how I have mine wired. Try the fuses.
Old Aug 26, 2008 | 12:41 PM
idodgimus's Avatar
tried the fuses... doesnt seem to be there!!!
its only the turn signals and fog lamps that dont work, the rest appears to be working as normal.
help?
Old Aug 26, 2008 | 01:32 PM
idodgimus's Avatar
sorted!!!
1. i hadnt reconnected the plug to the back of the hazard button so the turn signals didnt want to work
2. um.. .this is embarrassing... fog lights only go on when the headlights are on, i didnt know this until now.
feeling a little sheepish, but you live, you break stuff, you fix it and you learn!!!
Old Aug 26, 2008 | 01:37 PM
ETRNL's Avatar
Originally Posted by idodgimus
sorted!!!
dont feel bad i have done the same thing with the hazards. i thought i had to buy a new clock until i got to looking and i plugged it into the dummy plug that is right next to it for no reason. as for the fogs this will fix that... be sure to read the update for your truck..
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 17, 2015 10:13 AM
