brakes squeaking
Old Sep 3, 2008 | 12:09 PM
ugabulldog's Avatar
brakes squeaking
I just noticed my fron tbrakes are starting to squeak. It has been @ 100k since I had the pads changed. Should I spray w/ WD 40 to see if something else is causing the squeak?
Old Sep 3, 2008 | 12:16 PM
gearhead899's Avatar
are you saying it has been 100 thousand miles since you last changed your brake pads?!
Old Sep 3, 2008 | 12:18 PM
ugabulldog's Avatar
probaly more like 80k
Old Sep 3, 2008 | 12:19 PM
well theirs your problem lol
Old Sep 3, 2008 | 12:20 PM
NwRunner's Avatar
theyre called squeeler tabs, and your on them. Its an indicator you need to get your brakes changed ASAP before you destroy your caliper.
Old Sep 3, 2008 | 12:24 PM
yeah what he said.... your probly about 3 times past when you should have changed your brakes lol and for your idea about spraying the brakes with WD-40... thats gotta be the worst idea iv ever heard lol... no offense
Old Sep 3, 2008 | 12:37 PM
zlathim's Avatar
theyre called squeeler tabs, and your on them. Its an indicator you need to get your brakes changed ASAP before you destroy your rotors.
Fixed it for ya'.
Old Sep 3, 2008 | 06:04 PM
NwRunner's Avatar
indeed, im pricing brakes for mine now and i have all kinds of all this stuff running through my head!
Old Sep 3, 2008 | 06:11 PM
Team420's Avatar
Originally Posted by zlathim
Fixed it for ya'.
Actually...it works both ways.... let your pads get to the metal, and stomp on them...what happens? You blow piston seals in the calipers....
100k on front pads???? Where the hell did you get pads that last that long? I have to change mine every 15-25k.
Old Sep 4, 2008 | 06:05 AM
zlathim's Avatar
Well after 100,000 miles on one set, I can believe that. I've never seen a caliper like what you are describing. Are you saying that the seals end up contacting the bore of the caliper at a point that does not seal, or are you saying the pistons come all the way out of the caliper? I'm just curious, just cause I haven't seen it doesn't mean that it won't happen.
Old Sep 4, 2008 | 06:16 AM
Team420's Avatar
Ya...they will over extend pushing the boot out to far to seal...have seen it happen before.....although not on my runners.... usually on vehicles with only 1 or 2 pistons on the same side, these calipers may not have that issue as there are 4 pistons, 2 on each side..well at least the 91-95's do.
Old Sep 4, 2008 | 09:10 AM
ugabulldog's Avatar
I found the receipt where I bought the last pads, they say blue ceramic and a product # if anyone wants it. The squeaking has actually stopped and i will continue to monitor, probaly get pads soon as it seems to be about time. Yes, i will buy the same kind!!!
Old Sep 4, 2008 | 10:39 AM
Baloo's Avatar
I would monitor it on your way to the parts store to immediately buy new pads and replace them when you get back from the store.
Unless that 100 K includes 98K of constant highway driving, you're way over due. Even then I wouldn't wait or the next sound you hear will be metal on metal.
Old Sep 4, 2008 | 06:10 PM
NwRunner's Avatar
lol. The next sound you will hear is, "well sir looks like were going to have to do the whole front brake system, your total will be 700 dollars."
CHANGE THEM!
old87yota
Sep 9, 2015 12:39 PM
Scatterbrain
Sep 3, 2015 06:46 PM
Jake28296
Sep 3, 2015 04:58 PM
bfmcelroy
Aug 18, 2015 06:42 AM
CanRunner
Jul 20, 2015 01:29 PM
