Rear window, and remote locks not working, after battery dissconnect
Old Aug 20, 2008 | 05:01 PM
Yukon's Avatar
My car went to the body shop (rear ended) and it comes back, and the rear window wont go down with the key, or the remote. It will go down with the button. Also the remote locks don't work. I think it has to do with reprogramming the remote. But why wouldn't the window work?
I know I could search but I'm busy packing for school, and always lose track of time withe searching
Thanks in advance for any help
Old Aug 20, 2008 | 06:58 PM
Yukon's Avatar
Question, are the door lock switches supposed to work when the car isn't on, IE no key in it press the button and the doors lock? Mine aren't, but put the car on, and they work fine. The power windows work too.
That rules out a fuse right?
Old Aug 21, 2008 | 09:37 AM
Ron Helmuth's Avatar
check the rear wiper and the rear defrost, if both are non functional the rear window memory just needs re-set. Put it all the way down and all the way up, then recheck.
Can't help with the locks but yes I do think the remote module has to be reprogrammed or something.
Old Aug 21, 2008 | 03:54 PM
Yukon's Avatar
I tried to reprogram the locks but the power locks wont work when the car isn't in the run position.
Old Aug 21, 2008 | 04:43 PM
Yukon's Avatar
Rear wiper and the rear defrost are not working, but the heated mirrors work. And the keyhole switch doesnt work so I cant do the reset with it. I tried with the button to no avail.
Old Aug 22, 2008 | 07:27 AM
checked the fuses to be sure one did not blow?
Old Aug 22, 2008 | 07:48 AM
98runner210's Avatar
Just take it back and have it fixed right like it should have been the first time.
Old Aug 22, 2008 | 08:14 AM
Godzilla's Avatar
Check the latch/latch sensor on the liftgate. Spray some penetrant in it and let it drip for a bit. Also check the sensor that detects the window open/closure.
Old Aug 22, 2008 | 12:37 PM
Yukon's Avatar
yeah I should, but ive been avoiding taking the car apart in the parking lot during move in day. Where are they located? Does anyone happen to have a picture?
Old Aug 22, 2008 | 02:59 PM
surf4runner's Avatar
did you check to see if the remotes batteries are good?
Old Aug 22, 2008 | 03:10 PM
Yukon's Avatar
Yes it all worked 100% before they shop got it. But I will go test them to see now.
Old Aug 25, 2008 | 01:49 PM
Yukon's Avatar
Went to the local yota dealer and they said to just unhook the battery and then hook it back up. So they are no help. Anyone have any ideas? I'm going out now to Do the battery, and check ALL the fuses. Also try to check the window switches.
Old Aug 25, 2008 | 02:56 PM
Yukon's Avatar
got it all fixed. it was a fuse after all. the MPX B fuse in the engien fise block. fixed all the issuses
Old Aug 26, 2008 | 07:29 AM
Just remember fuses don't blow for no reason. I would keep an eye on it.
voiddweller
19
May 2, 2016 09:10 PM
Corey
Jun 19, 2002 11:06 AM
