- Question about 96-98 auto. shifter replacement
- Anyone have a picture of the steering stops?
- Exhaust? Need Help, done all the searches (Gadget)
- Midland 79 290 fit in a 98 4Runner dash?
- oem
- As promised new BFG's w/ pics
- Wtf...??
- Popping noise heard and felt when turning
- 205 tire + 5in wheel
- Score!
- wet floorboards? wierd
- CarChip vs PDA-Dyno
- 3VZE (3.0) 5 speed questions (R150 bellhousing?)
- SS Brake Line Problems
- Brake shield removal?
- After a $2000+- tranny rebuild,...
- Tranny question's
- Improperly Installed Supercharger????
- 90 v6 low compression on one bank
- Which engine for my 3slow 3.4 or Supra
- Yota OEM oil filters
- Hella Micro DE
- Taco seats
- 4th gen complaints, lots of voices!
- Mid size comparisons
- Rear tire Carrier Idea
- Kargo Master roof basket.
- 4Runner = Land Cruiser
- Happy Holidays!
- coil springs
- Got any ideas of what this could be?
- Temp Guage wiring schematics
- 3.0 idle adjustment
- Rear Wing Install
- Pics of Custom Airbox
- How much $$ could I get a 3rd gen for?
- 1981 SR5 Spare Removal?
- Have you seen this fob?
- Looks like I might be selling the yota
- TJM Alignment (T17)?
- SAS 3rd gen
- What types of bulbs?
- question
- toyota 2L diesels
- What does this switch do?
- Toyota factory locker
- Hella 500's Help!
- Brake Rotor Specifications
- Front sway bar bushings trashed!
- Remote car starter problems....
- Rav4
- Door handle -- exterior
- quick diff/breather question
- ticking during idling
- Proper tuning on 3.0L V-6
- Fuel pump question
- Smittybuilt bumpers
- Oil Pressure Sender... Frustrations....
- RightTurn Signal
- kind of an odd tacoma & 3rd gen 4runner ?
- Front suspension squeak over bumps, what is it?
- Air locker leaking internally
- Where to buy optima red top?
- Add-on trip odometer
- Anyone had rear quarter panel rust repaired?
- Oil in air filter
- Rusting bumpers and tailgates.....
- 99 Toyota Tacoma
- What Type of Grease
- Brake upgrade for 92 4x4 Truck
- nut on top of torsion bar adjusting bolt?
- frame dimensions 91 runner
- coilover suggestions
- Home-made rear cargo box
- sluggish acceleration 4cyl
- Tacoma and 4runner doors/panels the same?
- Air Intake Sensor Mods
- 98 SR5 alarm system ?
- Tire Plug Question
- towing 4500 lbs for 1200 miles?
- 3.4 Downey Headers
- leather repair
- tps sensor
- Wiring Lights
- front driver side wheel well
- Trim Packers - where to get?
- Rear wiper problem
- AIRAID Intake Tube
- Idle spped issue
- Pricing A 22re Head For 86 4-runner
- Odd vibration during idle
- Rear springs...
- Canadian Hood Protector
- help finding a bigger gas tank
- One new tire, 3 older tires... what to do?
- Want to increase range of factory alarm
- Anyone tried bumping up timing on a 3.0?
- Just installed Magnaflow hi-flow cat
- 2000 Fuel Gauge Accuracy TSB EL010 and Me
- Tacoma dealer buyback... Opinions
- 3.0 Problems: Searched, need more
- Mike @ Extreme ?????????
- San Diego Toyota parts / auto wreckers
- Just saying Hi
- 4th gen with tacoma skid plate and hooks
- Quick Question About Tail Lights
- 2005 Tacoma info
- 1000 Watt AC inverter Q's
- Rock Sliders for a 1980 Pickup
- Advice please
- Window replacement recommendation for Portland, Oregon
- Check out my new site!!
- Tacoma fender flares
- Minor rust questions
- engine identification
- Sticker removal from rear window question
- CHEAP: Mounting Cell Phone
- question about gears and a locker
- Changing My Name To: Gottayota!!!!!!!!!!!!
- Ticking - getting louder...
- removal of old badges
- gas vs. oil charged shocks ???
- V6 Water Temperature Sensor
- running boards
- Temp Guage
- good books
- WTB Stock 4runner airbox 1999 3.4
- CAI install troubles
- question for Aurora Sandman
- Valves bent?
- 4H question...
- Please help pass CA smog test
- ABS question
- Where to place jack stands?
- The transmission that goes bump in the night..
- universal axle housing?
- Tbs...
- one last hope. . .
- Myths of Coil springs, spacers and tbar cranking
- purchasing a 00 S/c'd runner?
- Defroster
- Wheel cleaning tip!
- factory sunroof transplant? glass replacement?
- $60-$100 Mod any ideas?
- Brake question after changing the fluid
- lost a bolt *into* the hood of '03 Runner...
- Tranny Fluid In Radiator
- looking for fender flares
- whos got intake on their 2nd generation 4runner?
- 3RD gen taillights for 2nd gen
- exhuast Question 2
- ats a arms
- 94 4runner for sale
- buying tacomas
- Costs of owning a 4Runner (Breakdown)
- D-pillar mirrors
- New Runner, What mods should I do??
- Oversized amsoil filters
- Online (or maybe not) parts question
- belt problem?
- Quick answer needed. Should I wait for Downey or go with Northwest Off Road?
- Lower Control Arm
- humidity and TPS
- 05 Tacoma
- Finally got my Hilux corner lights
- 16" brake question?
- almost finished bobbing the top...
- Rear spring coil isolater ?
- Screw Removal
- Engine died, no power, ?electrical?
- Gears and lockers
- Wet Okole Seat Covers
- 3in. body lift,negative affect on shifter?
- code 61 speed sensor
- 32x11.50x15 Interco Super Swamper SSR
- Back window wont go down
- Yet Another Stereo Question(3rd Gen)
- Insane 90k Service
- headlight flickers
- engine question OVERHEATING
- Lift installed
- Intermittent slipping clutch
- best palce to get arb
- How do you know if its Certified?
- New BFG's Coming
- Are there any differential upgrades for my 4Runner?
- Headlight bulb part number help....
- Rancho shock bushings
- HELP! HELP! HELP! Another Problem!! (Cams)
- Curiosity killed the freaken window
- Tps
- E-locker question
- New Alpine/Uniden Install
- Stinky Transmission
- What are the limits of mostly stock Toyotas???
- 4th Gen V6 vs V8?
- How do you and which pins to check codes?
- 7mgte towing power?
- Onilne Used Parts Dealers
- Gas gauge how do I fix? 96 runner
- 3.4l engine parts innerchangable??
- Reverse problem
- Drag race with new Z
- Popular SportEdition options from the Factory
- Remote Hatch Glass Opener:
- Lost the radio!
- Why can't I find these things 4 my 03 V6 4Runner?
- ebay supercharger hurry
- flush?
- 3.0 fuel pressure regulator ?????
- 98 Tacoma 2RZ motor info
- Who has 'em?
- Master rebuild kits... EPN vs Top Line vs OEM
- Will Worn Pitman & Idler Arm Making Driving Dangerous?
- poly body mount kit for tacoma
- rough idle when warm???
- Yota (3rd Gen/Taco) Front Wheel Bearings
- Oil change question - 3.4L V6
- billet grills
- Clunk from rear hatch area?
- 3.4 swap getting started
- 2nd Gen 4wd work few second
- I got pics now!
- Exhaust Installed !!
- squeeky 4wd boot...make it stop?
- Headlight lens - Busted - Options?
- 4th Gen+Dual Borla+Cold=Rattle?
- rear hatch electrical 3rd gen probs
- high pitched noise - cd player
- new to this forum & code 61
- Difference between Limited, Sport, SR5 (3rd Gen)
- maybe a stupid question??
- ARB & Winch
- gearing question?
- interchangable tranny
- Advice For Driving Once A Week
- leaky axel seal
- 2nd gen center console lid??
- 4 cyl.
- Auto Trans Shop in So Cal?
- How is your 04 4Runner rear defogger performance during snow?
- Difference between 4sp man. and 5sp man.?
- 1998 4runner?
- Rebuild my 22R OR buy a remanufactured engine?
- A/C problems
- more cb questions...
- Some pics of new mods...
- Ready to buy my 04 4Runner, need your help.
- E-Locker
