Front sway bar bushings trashed!
Old Dec 21, 2003 | 11:22 AM
transalper's Avatar
I recently noticed that my front sway bar bushings are trashed. Both are almost totally split in half. Is this common to all 3rd gens or did it happen because of my suspension lift?
Old Dec 21, 2003 | 09:16 PM
Sucellus's Avatar
Mine are pretty much exploded too. Good excuse to get a new sway-bar, disco's and ES bushings if you ask me....But that may just be me.....
Old Dec 21, 2003 | 10:23 PM
RTdawgs's Avatar
the stock sway bar end links will go to hell after a lift. several people report them busting in half, im sure everyone's bushings wear out fast.
the end links need to be raised the height the suspension is raised, otherwise too much stress on the end links.
theres your excuse to get swaybar discos designed for the amount of lift you have.
Old Dec 22, 2003 | 06:10 AM
transalper's Avatar
Originally posted by RTdawgs
the stock sway bar end links will go to hell after a lift. several people report them busting in half, im sure everyone's bushings wear out fast. the end links need to be raised the height the suspension is raised, otherwise too much stress on the end links. theres your excuse to get swaybar discos designed for the amount of lift you have.
I already have Lars' extended discos, so I need to use this as an excuse to get something else. Maybe an engel freezer fridge or a pull-pal?
The bushings I'm talking about are the ones where the sway bar connects to the frame. Part #15 in this pic:
Old Dec 22, 2003 | 06:32 AM
RTdawgs's Avatar
oh ok.
maybe youre tightening your discos too much, or not enough. maybe its just time to replace them?
bump for someone whos had this prob.
Old Dec 22, 2003 | 07:48 AM
transalper's Avatar
Thanks for the bump and the chance to clarify. My sway bar end link bushings are fine. It's the other sway bar bushings that connect the sway bar to the cross member that are trashed.
Any body else have problems with these sway-bar to cross-member bushings splitting in half?
Old Dec 23, 2003 | 03:00 AM
Runner4's Avatar
Are you talking about the bushings located in the middle of the chassis where the sway-bar crosses the frame? I have just noiticed my passenger side is completley split and needs to be replaced. I don't have any lift either. Anyone know how to replace these?
Old Dec 23, 2003 | 04:47 AM
transalper's Avatar
Yup, those are the ones. It's interesting that yours split as well. I suspect this is a common problem.
Replacing them looks pretty straight forward, but I haven't done it yet. I do have the part in hand. It's called a "Front suspension, Stabilizer bar, Bushings, BUSHINGS, 4-Runner - 4WD COIL SPRING" on partznet.com and costs around $6. I'll do at as soon as I can find a dry driveway on a warm day.
Old Dec 23, 2003 | 04:55 AM
Runner4's Avatar
Have you experienced any noises while turning as I have explained in this thread: Popping Noise
that may be caused by the busted bushings?
Old Dec 23, 2003 | 05:24 AM
transalper's Avatar
Have you experienced any noises while turning as I have explained in this thread: Popping Noise that may be caused by the busted bushings?
No popping noise. I did have some annoying suspension squeaks and I noticed the split sway bar bushings while I was spraying lithium on all the front suspension components. The lithium took care of the squeaks.
Old Dec 23, 2003 | 05:40 AM
midiwall's Avatar
When Dr. Z, RidgeRunner and I were lifting my truck a few weeks ago, I noticed that my front swaybar bushing were trashed. The passenger side was torn in half and basically not doing anything.
I ordered up a set of greasable Energy Suspension bushing from Sumit racing, put them on about a week ago.
There are various related words in these threads:
https://www.yotatech.com/forums/show...threadid=20770
https://www.yotatech.com/forums/show...&threadid=9960
Old Dec 23, 2003 | 06:13 AM
transalper's Avatar
Thanks for the links. I will definitely try out the greasable bushings.
Old Dec 23, 2003 | 08:48 AM
data's Avatar
Senior Member
my fronts were split in the same place. i just ordered me a set from energy suspension.
88sasturbotoy
Jan 30, 2026 01:57 PM
coffey50
Jul 28, 2015 10:55 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
andrewtexas123
Jul 23, 2015 11:22 AM
Vargntucson
Jul 4, 2015 12:15 PM
