Energy Suspension
Old Apr 28, 2003 | 09:28 PM
smr4runner's Avatar
Energy Suspension
Whats up Ya'll,
Im getting massive clunking under the rig.
Im needing to replace my anti swaybar bushings for the front/rear. Also the steering rack bushing.
Looking for feedback on the Hyper-Flex greasable polyurethane bushings for the anti-sway bars.
If so do you have the part numbers?
Is there a kit the includes all that I need to replace the old bushings?
Old Apr 28, 2003 | 09:35 PM
BajaTaco's Avatar
Not sure about the sway bar bushings, but I think we have the same steering rack. (I have a 98 Tacoma).
I replaced my steering rack mount bushings over the weekend. They lasted about 92,000 miles before they got loose on me, so I was pretty happy considering how much abuse I've given the ol' rack. While I had it up off the ground, I checked the play in the rack and the ball joints. Everything is good. (I am still on the original ball joints & tie-rod ends)
http://www.energysuspension.com/toyt1.html
Part# 8.10101-G ("G" for black or "R" for red) I bought mine through my local AutoZone store.
Anyway, on the rack bushings... some of you might be familiar with the install - some not. It was a fairly easy job (not as bad as everyone has been saying) and I am happy to say that Energy Suspension now includes the proper diameter metal sleeve for the middle bushing (people were having to drill or hone them out).
There are a couple of write-ups here...
http://www.keystonekrawlers.com/Mods...eeringBush.htm
http://www.d4t.4t.com/rack.html
The only things I might add to what these folks have detailed, is that...
1. Use some liquid wrench - soak the bolts and nuts before you get started with the wrenches.
2. In addition to a socket with ratchet, you might try an offset box wrench with a hammer to get a couple of the bolts loose.
3. Use a "Super Bar" to manipulate the rack while you work on it. It's perfect for the job.
http://www.plazahardware.com/tools/s...ools/Pry_Bars/
Old Apr 29, 2003 | 06:44 AM
TDiddy's Avatar
Thanks for the links to those write-ups. I have the kit for my 4Runner, but haven't got around to installing it yet.
Old Apr 29, 2003 | 06:50 AM
rimpainter.com's Avatar
I have had experience with Energy Suspension on one of my past vehicles (95 SI), and the kit was awesome. Totally eliminated wheel hop on my launches at the strip, and tightnened everything up all the way around.
I realize you are asking about a totally different vehicle, but I wanted to put my .02 about the quality of the bushings.
Old Apr 29, 2003 | 07:43 AM
jalaber's Avatar
9-5161-G, 1" greasable sway bar bushings, black, for factory front bar
9-5156-G, 3/4" greasable sway bar bushings, black, for factory rear bar
I like them. Here is my Write Up
Old Apr 29, 2003 | 09:13 AM
smr4runner's Avatar
Hey Guys.,
Thanks for all the info and links. It will help out immensely.
Tom,
What does the kit include? Is it the Hyper Flex design?
Part number?
Thanks again
LittleUgly
15
Jan 2, 2020 01:30 PM
live4soccer7
May 11, 2016 06:52 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
ktm192k
Oct 1, 2015 08:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
