Rear Swaybar Bushing Questions
Old Nov 11, 2003 | 12:00 PM
CTB's Avatar
CTB
Hey guys,
I think I'm going to order some replacement polyurethane replacement bushings for my rear swaybar, but for the life of me, I can't find any part #'s for them anywhere. Did most of y'all get them from Energy Suspension? If so, do you have the part #'s for them? I did a search at YotaTech and 4x4wire, and just can't seem to find them anywhere. Any info you've got would be greatly appreciated. Thanks a ton guys-
CTB
P.S. - Should I be looking for greasable ones, or will regular polyurethane be fine?
Edit:
P.S.S. - I am also looking for part #'s/info on the rear swaybar end-link bushings as well. Thanks again-
Old Nov 11, 2003 | 12:20 PM
There are some great bushing avail through Energy Suspension. I recently installed greasable sway bar bushing/brackets front/rear and endlinks from this company. You can look at their web site Energy Suspension (949 361-3935).
I ordered the items from Summit Racing (800 230-3030).
9-5161-G, 1" greasable sway bar bushings, black, for factory front bar
9-5156-G, 3/4" greasable sway bar bushings, black, for factory rear bar
Best of Luck
Andrew
Old Nov 11, 2003 | 12:27 PM
CTB's Avatar
CTB
Thanks a ton for the info Andrew.
Old Nov 11, 2003 | 12:55 PM
midiwall's Avatar
I JUST ordered exactly what Andrew gave you. The only thing that I can add to this is that they also come in Red:
Front:
http://store.summitracing.com/defaul...161R&x=21&y=11
Rear:
http://store.summitracing.com/defaul...156R&x=21&y=11
And, I hit up Lowe's with the list of parts that ALBPM gives in the 5th post of this thread:
https://www.yotatech.com/forums/show...threadid=19937
Old Nov 11, 2003 | 01:05 PM
CTB's Avatar
CTB
Thanks for the info Mark - I appreciate it.
So, does anyone have any ideas for the rear end-link bushings?
Old Nov 11, 2003 | 04:17 PM
CTB's Avatar
CTB
Back to top
Old Nov 11, 2003 | 07:38 PM
CTB's Avatar
CTB
One last shot...
Old Nov 11, 2003 | 07:56 PM
ALBPM's Avatar
Look under Handling here ....
J.A.'s
Old Nov 11, 2003 | 08:08 PM
keisur's Avatar
I just bought an ES endlink bushing kit from pepboys for about 7 bucks, drilled out the washers and installed them. they fit perfectly. can't tell you the part number but they only had one size when I went there.
Old Nov 11, 2003 | 08:14 PM
CTB's Avatar
CTB
Awesome, thanks for the help fellas. I really appreciate it.
Old Nov 12, 2003 | 07:45 AM
sandcrawler's Avatar
how difficult is it to change out the bushings on your own?
as simple as it looks, or are there any hidden gotchas?
sorry to hijack your thread!
Old Nov 12, 2003 | 08:30 AM
keisur's Avatar
no, unscrew nut, remove old endlink washers and bushings, install new ES washers and bushings. DO THE swaybar bushings first and then the endlinks. best to completely remove the whole thing then reassemble starting with the swaybar bushings.
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
