engine question OVERHEATING
Old Dec 16, 2003 | 04:53 PM
lbb-1's Avatar
Got a guy wanting to sell me his 3.4L out of a 01 tacomma 60K on engine.
He said that he forgot to turn on his fan and blew a hose.
Other than that engine is fine according to his mechanic buddy.
Anyway I'm going to check it out tonight.
If the hose blew then the heads should have not warped Correct?
Should I get a commpression check first>?
$1000.00 for complete engine everything ecu harness ect
GO For it or Run
Thanks
Old Dec 16, 2003 | 04:57 PM
zedex's Avatar
If the engines fine. Why is he selling it?
Definitely do a compression test. I myself would never buy a motor that has been cooked.
Old Dec 16, 2003 | 04:59 PM
AgRunner06's Avatar
Exclamation Re: engine question OVERHEATING
BS!! I'm not sure if the fans are electronically controlled or by a mechanical clutch but either way it isn't on a switch unless he has swapped in an aftermarket fan. If it got hot enough to blow a hose then it could have really done some damage internally.
Think about it for a second. Why would someone sell a perfectly good engine with 60K miles on it for a grand? Hell, why would he have put in a new engine if there wasn't anything wrong with the old on in the first place?
IMO you will lose if you make this purchase.
Run
its2slo's Avatar
why is it out?
amusement's Avatar
add a leak down test to the compression test
Old Dec 16, 2003 | 05:01 PM
its2slo's Avatar
the leakdown is the only test i think he can do since its out
Old Dec 16, 2003 | 05:30 PM
MTL_4runner's Avatar
Get one out of a wrecked vehicle not someone that smoked it.
You want accident damage which is usually just cosmetics and small stuff.
An engine like you are talking about sounds like a serious headache.
Just take a deep breath and keep looking. :pat:
Old Dec 16, 2003 | 07:52 PM
lbb-1's Avatar
saw the engine
Turns ot to be a bunch of young guys in a project garage.
Well the engine is off a automatic 96 4runner I need a manual from what I understand as I'm still learning.
These guys were telling me its the same engine regardless and all I need to do is switch the fly wheel and a couple of other things.
Then all the other parts were mixed off a 01 tacoma plenem intake maifold and starter, compresor ect.
Did not get a warm fuzzy
ohh well
Old Dec 16, 2003 | 08:00 PM
its2slo's Avatar
the must be 5spd thing doesnt make sense to me either, it all bolts up to the block the same. i put an 5spd engine in my automatic tacoma
Old Dec 17, 2003 | 04:04 AM
Re: saw the engine
ohh well
All you need is a different flywheel for 5spd vs Auto.
They are correct the engine blocks are the same but there are more than a few things to change for a swap.
Check out thess links for all the details:
http://www.automotivetalk.net/showmessages.php?id=633
http://www.pirate4x4.com/forum/showt...5&pagenumber=1
Old Dec 17, 2003 | 05:44 AM
rimpainter.com's Avatar
Old Dec 17, 2003 | 07:54 AM
lbb-1's Avatar
BLEW HOSE
Yeah Because he was drunk (young kid) maybe 20 something. Forgot to turn on his fan in the desert of all places.
Anyway I'm still hunting for an engine
later
Old Dec 17, 2003 | 08:48 AM
Unless he installed an aftermarket fan with manual switch, the 3.4 will not have any cooling fan that is electrical or driver manipulated. That's what I dont understand.
Oh well, you crossed that engine off anyway. Good thinking.
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
