Yet Another Stereo Question(3rd Gen)
Old Dec 16, 2003 | 06:12 PM
cool rob's Avatar
I'm about to upgrade my stereo! And yes, I did do a search w/ out yielding definitive answers for the following questions:
1. What aftermarket rear speaker did you install(model#,if possible, and size) WITHOUT having to make any modifications to the door panel to allow the window to come all the way down?
2. Can I expect to get poor FM reception w/ an aftermarket head unit, and how can I overcome it?
Any and all recommendations are welcome. Thanks.
Old Dec 16, 2003 | 06:26 PM
Vato Loco's Avatar
1. Pioneer TS-A1357 5.25" 2-Way Speaker
2. I had no problems with reception on the aftermarket stereo, I would say you get better reception.
Old Dec 16, 2003 | 06:32 PM
cool rob's Avatar
Vato...what head unit are you running? how did the diversity antenna factor into the install? thanks.
Old Dec 16, 2003 | 09:07 PM
Mystickal's Avatar
As far as the head unit stereo reception goes, everything will be just fine with an aftermarket unit. If you're really concerned about reception, the key thing to look at for FM reception is the headunits FM sensitivity - This number is expressed in decibel femtowatts (dBf). The smaller the number, the greater the ability to pick up weaker stations.
The diversity antenna shouldn't even be a factor in your headunit selection. If you often travel in the fringes of the broadcast area of your favorite stations, then you should pay close attention to the FM sensitivity. However, for most normal, urban, day-to-day driving conditions just about any head unit you put in will pick up your local stations just fine.
~Bill
Old Dec 16, 2003 | 09:37 PM
Mystickal's Avatar
It occurs to me that your question on the diversity antenna was directed to how was it hooked up to the aftermarket head unit, yes?
Your reception should be just fine with only the power antenna hooked up the the head unit. Every aftermarket head unit I can think of only has a connector for one antenna, and that size is the one for the power antenna, not the diversity antenna. If you really want to keep both antennas hooked up, you can pick up an adapter for about $5-10 and plug both of 'em in.
~Bill
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
theking11863
Mar 19, 2016 09:36 PM
jerusry
Oct 19, 2015 05:28 PM
93toyoguy
Aug 2, 2015 07:41 PM
