E-locker question
Old Dec 16, 2003 | 10:04 AM
NVRSASTK's Avatar
E-locker question
What will happen if I put a rear e locker in my 4runner? with out changing the front stock 410 gearing to match the rear 430 gearing?
So I would probably have to find a front 3rd member to match the rear correct?
I'm trying to figure out how to lock my vehicle up the cheapest but strongest way. ARB front and rear are $1600.00 without labor. Does this sound about right?
Old Dec 16, 2003 | 10:09 AM
rimpainter.com's Avatar
You are asking for trouble if you do not match the diff ratio's.
Have you considered an Aussie Locker? It is a full time locker without the common side effects. And for $200, you just cant beat it.
It should be out early next year. Try a search also, there is a ton of info on e-locker retrofitting.
Old Dec 16, 2003 | 10:19 AM
44Runner's Avatar
you could always get a 4.10 e-locker. they are available from the factory in 4.10, 4.30 and 4.56...
Old Dec 16, 2003 | 10:26 AM
NVRSASTK's Avatar
Thanks
I though I could ...I have had a hard time finding a 410. Everyone I have found is 430. What do you think it will cost to put one in not encluding the locker itself? I could just hard wire it past the computer couldn't I with a toggle switch?
Old Dec 16, 2003 | 10:31 AM
http://www.phorunner.com/e-locker.html
Old Dec 16, 2003 | 10:35 AM
runnerboy97's Avatar
I was on the hunt for an elocker, but cant seem to find any 4.10's for a decent price. I talked with the guys at 4x4 connection and they are gonna put in an ARB for me for about 1100 out the door. SO i cant wait to get that done. good luck with the elocker
Old Dec 16, 2003 | 10:42 AM
NVRSASTK's Avatar
for rear only
1100.00 for rear only..... That seems very high. I had a shop quote me 1780.00 for front and rear and I thought that was high.... Of corse a cheap compressor not ARB's....
Old Dec 16, 2003 | 10:50 AM
Mojo_Risin's Avatar
Hmmm. Are you guys looking at http://www.car-part.com/ ?
Search under "Carrier".
John
Old Dec 16, 2003 | 11:01 AM
Yes, thats for the locker 600, compressor 200, new bearings seals and the labor. I didnt think it was too bad a price.
yes i looked there, i couldnt find any decently priced 4.10 lockers though.
Old Dec 16, 2003 | 12:05 PM
transalper's Avatar
There are a bunch of 4.10 e-lockers in the $300-$450 range on car-parts. That sounds decent to me. Call a few of 'em up and work a deal. Get them to include the switch, ECU, and wiring harness and you have a complete set-up that is ready to swap in with the housing mods. Make sure you have them include the plug and pigtails with the swith and ECU.
Old Dec 16, 2003 | 12:37 PM
AznSky's Avatar
Boo, no 3.90's. I guess my only way is to totally regear fr/rr and throw lockers in fr/rr huh?
Old Dec 16, 2003 | 12:43 PM
fpkelly's Avatar
How in the world do you have 3.90's? I thought the lowest 4Runners went was 4.10. Anyway deals can be found on the elockers you just need to be patient and keep checking car-part.com.
Old Dec 16, 2003 | 01:00 PM
AznSky's Avatar
I got like the most basic 4x4 you could possibly get.
No moonroof, 15" tires, 225/70's.
yea.....I didn't know crap about trucks when I bought her.
anyways, you could regear mine and throw lockers in for me right?
Old Dec 16, 2003 | 01:03 PM
fpkelly's Avatar
I can throw lockers in if you get it regeared first. I have no clue on how to properly setup gears.
Old Dec 16, 2003 | 01:09 PM
transalper's Avatar
Front Carrier with 4.30s - $400 or less
Rear Carrier with 4.30s and e-locker - $400 - $450
ECU, switch, and harness - ?? I got mine for $40
Housing mods - ?? free if you have access to a welder
Misc expenses - bolts, gasket, rtv, etc - less than $50
Labor - do it yourself!
That's around $900 to get better gearing and a rear locker. Less if you can find the diffs and pull em yourself. That's still less than the rear ARB. If you got the moola, throw in the front ARB for another grand or so.
Old Dec 16, 2003 | 02:16 PM
AznSky's Avatar
If only it was that easy.......I would throw down 900 in a Heartbeat!!
I wasn't sure about the front, but all I need is just a front carrier? Seriously, if it was this easy I would totally do it. But then you've got the labor part where I don't have a clue about.
Old Dec 16, 2003 | 04:31 PM
transalper's Avatar
The front carrier is pretty easy to swap out. No special tools. There are a lot of good write-ups. The rear housing mods require a couple welds, but other than that it's jsut some grinding and drilling/tapping. The rest of the job is pretty straight forward wrenching.
Swapping out both diffs can be kind of an intimidating project if you haven't done much wrenching, but this could be your chance to become a real shadetree mechanic and learn some skills that come in VERY handy out in the bush. You can be the guy in your group that calmly pulls out his spare CV axle and swaps out the busted part in less than 30 minutes! Do you have any relatives or friends who are gearheads? Make friends with the gearheads at work and bribe them with homebrews or something like that. Try joining a local 4x4 club. I was lucky enough to have a local club guy help me with my first rear diff swap and ARB install just a few years ago. Take that first step under the shadetree and you'll be glad.
Old Dec 16, 2003 | 04:44 PM
AznSky's Avatar
the biggest gearhead I know that would know how to do this stuff would be forrest (fpkelly). Now if I was back home in Az. then it'd be a different story, cuz there I would have a good amount of resources to go to. Out here I don't really know many people. And really no local 4x4 clubs in Indiana (at least Toy related) And yes, this project is very intimidating, however, to be the guy that pulls out a spare axle and swaps in in 30 min. would be a dream come true.
edit: I'd even be up for driving to different states to have someone show me how to do the swap, that way I work on my rig and learn everything with help. *hint* *hint*
Old Dec 16, 2003 | 05:40 PM
transalper's Avatar
See, you do have the skills to schmooze and get this job done! Now you just gotta find someone locally who can do the axle housing mod welds and you'll be set. Another option to consider is getting the whole rear axle - housing, 3rd, and all. That way you could do the swap without having to do the housing mods. It would add a bit to the cost, but would simplify the install.
It took me nine months to get my lockers installed. I found the parts and pounced when the deals showed up. Then I took my time with the wiring. Then the planets aligned and my brother and I swapped out both diffs in just over a day. Be patient, grasshopper, and you will be locked.
Jun 1, 2021 01:51 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
AaronM
Jul 8, 2015 07:15 PM
