interchangable tranny
Old Dec 15, 2003 | 05:14 AM
motrhedx81's Avatar
I've been looking into doing a engine swap. I was wondering if anyone knows if the V6 5spd trannies (R150F) is the same size, and output spline count and mate up to my transfer case, as my 22re 5spd (W56). So that I can change engines without having to mess with my driveshafts, all my shifters go to the same place.
Old Dec 15, 2003 | 07:15 AM
toy283's Avatar
In a word, No. The V6 tranny output is 23-spline, W56 trannies are 21-spline. You can get a 23-spline input gear from Marlin for $165 but then you have a difference in bolt pattern to deal with. You'd be in luck because Marlin has the appropriate adapter for that as well. So, with the adapter and new input gear, you'd be able to bolt a gear-driven t-case up to your V6 tranny. Why not just get the matching transfer to go with your tranny?
Old Dec 15, 2003 | 08:02 AM
motrhedx81's Avatar
don't really know..... i always heard the t-case for the 22re was bullet proof
Old Dec 15, 2003 | 08:22 AM
motrhedx81's Avatar
toy283, I appreciate all your advice.... looks like this swap can get pretty expensive but would be worth it
Old Dec 15, 2003 | 08:56 AM
toy283's Avatar
It would also be the only way to go duals later if that's something you might be interested in.
Also, upon re-reading your original post. Swapping in a R150 tranny in place of a W56 will move the shifters forward a little. They are not in the same location.
Old Dec 15, 2003 | 09:06 AM
motrhedx81's Avatar
dual cases? which combo, the v6 tranny and 4cyl case or v6 tranny and case?
Old Dec 15, 2003 | 09:17 AM
toy283's Avatar
You can only do dual cases with gear-driven 4-cylinder cases. But, if you go 23-spline (which is a must behind a R150 tranny) they are stronger than the V6 chain driven case.
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
