Engine died, no power, ?electrical?
Old Dec 16, 2003 | 09:54 PM
FrustratedJane's Avatar
Unhappy Engine died, no power, ?electrical?
My 4runner wouldn't start (3 weeks ago), so I jumped it and I took it to Autozone to test the battery and alternator. Everything checked out ok but I decided to replace the battery anyway. The car has been starting well up until today. The car has also been idling rough and a check engine light (code 71-emissions rich/lean mixture) has been on for months. I haven't done anything about this since it California only, yet I suspect its causing the it to idle rough. I started the car to let it warm up and all of a sudden... it died, no lights, no power, no nothing. I got it jumped and as soon as I put it in gear it stalled again and lost all power. I have been unable to move it without having it stall. My car is still in the parking lot at work since I can't seem to get it started or keep it running. Please help !!!!
Old Dec 16, 2003 | 09:58 PM
its2slo's Avatar
what engine and model is it?
Old Dec 16, 2003 | 10:12 PM
Oh yeah, 1994 toyota 4runner 4WD SR5 3.0L V6
Old Dec 16, 2003 | 10:31 PM
Tacoma Dude's Avatar
Is it possible that the rough idle and the engine not starting are 2 separate things? Guys?
How'd the idle sound before you put it in gear? Strong?
This may sound like a dumb question (but I know this from experience :pat: ) are your battery cables on tight?
Old Dec 16, 2003 | 10:33 PM
Hyperlite's Avatar
Check your grounds and make sure you have you clamps on the battery terminal as tight as you can get them. Pull the fuse that says EFI and leave it out for 15 minutes, should reset computer codes. If light reappears, check your exaust pipe and headers. Also check your air filter or intake tube for dirt or mud.
Old Dec 16, 2003 | 10:37 PM
its2slo's Avatar
mine was the starter/alternator harness where battery acid ate it away, why i use gell cell bateries now.
but it could be the maf, or the crank pulley, or a timing belt, or :pat:
Old Dec 17, 2003 | 08:45 PM
Weirdest thing....We left the car and took the battery home to test it and it was fully charged. Today, we put the battery back in the car and I had power and the engine cracked over like no problem. We were going to trace the electrical starting from the battery but now its working. I am worried about when this intermittent problem might strike again. Thanks for your suggestions. I will be checking the connection to starter/alternator. Is there a trick to pulling out the EFI fuse? I had wanted to do it earlier but did not want to force anything. The battery cables are tight and clean, I changed the ground connection a couple of weeks ago. The car still idles rough yet it doesn't stall anymore when I put it into gear. Last night, the car sould shut off as soon as you started to let out the clutch. The darn thing also pops out of first all the time
I will also look into the MAF (how will I now if its working properly)
Could a starter relay cause this? I wonder if I have a loose ground connection somewhere that could be causing an open circuit. The 4runner is running now and I am afraid to drive it anywhere and become stranded. Thanks guys.
Old Dec 18, 2003 | 12:28 AM
ByThaBay's Avatar
i had a similar problem on my 1982 toyota cressida. check your fusible links...
Old Dec 18, 2003 | 12:57 AM
Just pull it out
I dunno if yours has the convenient tweezer thingy but when I've encountered problems in the past a nice set of needle nose pliers worked just fine
Old Dec 18, 2003 | 01:36 AM
frederickg's Avatar
It sounds like the battery is being drained or isn't getting charged by the alternator (which has a built-in regulator.
Sometimes it's as simple as cleaning the positive battery post.
It's a good idea to clean the negative as well.
WARNING: The acid from the battery (sulphuric) will eat through your clothing and will burn your skin.
Recommend Backing Soda and Water solution if the terminal is highly corroded.
Then a battery post cleaner or smal wire brush to clean the post so they're shiny. Clean the termina as well.
A Battery Brush works best for both and usually be picked up at a Wal-Mart for less than $5.
- Good Luck
Old Dec 18, 2003 | 01:43 AM
frederickg's Avatar
- Good Luck
Old Dec 18, 2003 | 10:24 AM
Waterboy's Avatar
I know this is far from you biggest problem but you can check this thread out for a fix.
https://www.yotatech.com/forums/show...ps+out+of+gear
Also it sound like your alternator is bad. I had an S-10 with a bad alternator that I could jump but as soon as you put a load on the engine (such as putting it in gear or turning on any electronics) it would die. Good luck with fixing it.
Old Dec 18, 2003 | 04:08 PM
Thanks for the advice. I'm going to take out my alternator this weekend and have it checked. I had it checked at autozone while it was in the car and they said it was fine. The battery terminals and clamps have been clean and they're tight.
Thanks for the link to the shift lever seat and bushing. Sounds like something that I will be able to do and it will save me from a lot of grief.
My friends tell my that my car is possessed.
Old Dec 19, 2003 | 04:05 AM
Time to exorcise the damned thing
Good luck!
Old Dec 20, 2003 | 08:55 PM
Haven't been able to find the problem. My tuck has been working ok now.
I worked on the shifter today and its much better! I'm not popping out first anymore.
Charecter1
Nov 6, 2023 10:08 AM
Jun 1, 2021 01:51 PM
Colington
Mar 8, 2020 09:51 AM
coryc85
Sep 9, 2015 06:24 AM
Yota.Jay
Jul 23, 2015 08:08 PM
