Wheel cleaning tip!
Old Dec 17, 2003 | 08:21 PM
Plays_with_Toys's Avatar
Wheel cleaning tip!
I put this in my mag-chloride thread, but I figure it would get more attention here.
Anyway, it's winter and I didn't want to have the magchloride sitting on my wheels and making pock marks and such. I also didn't want to use a hose and wash off the wheels because I didn't want to have any of the pipes freeze and break.
So I went to Target and in the cleaning supply aisle was a 32 oz. spray bottle from rubbermaid. Being the only spritzer there I bought it. $3 later and at home, I put a little bit of meguiars car wash soap in it and filled it with water. I swished it around and it got nice and sudsy. I then sprayed the wheel about 10 times and after the water had run off of it a little I wiped it with a rag. The wheels are now spotless.
The sprayer is top notch. It is very powerful, with a concentrated stream, not a mist. It was powerful enough, the water was splashing back at me from 2 feet away. It took me all of 7 minutes to do the wheels.
You could also use it elsewhere to spot clean in the winter, or probably clean the whole truck. Definately a worthy investment to those in the winter wonderlands.
Old Dec 18, 2003 | 04:30 AM
lee's Avatar
lee
awesome.
my strategy has always been to take a wet rag, run over all the dirt, then i spray this wheel cleaner fluid (will get the exact name if you want), spray all over the wheel, then take a dry towel and wipe it all down.
works like a charm.
Old Dec 18, 2003 | 05:36 AM
midiwall's Avatar
Originally posted by lee
...then i spray this wheel cleaner fluid (will get the exact name if you want)
Yes, please do... If it'll cut through brake dust, I'm all ears (and wallet, and elbow grease)!
Old Dec 18, 2003 | 06:10 AM
lee's Avatar
lee
ill check it in my car at lunch time
Old Dec 18, 2003 | 07:31 AM
X-AWDriver's Avatar
I was pretty anal about my wheels being clean on my Eclipse and I tried a ton of stuff and I still had to do a onceover with a rag to get all the dust.
Most of the common spray on,spray off stuff worked really well with minimal wiping.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
terminator
Jul 27, 2015 07:13 PM
calderp
Jul 27, 2015 09:58 AM
skoti89
Jul 6, 2015 07:45 PM
