- 3rz 4port vs. 8port heads
- Weirdest problem ever on 2001
- Tundra Brakes 199mm, fitting question.
- High NOX second failure
- magnaflow muffler noise level 14' or 18'
- Adding the aftermarket Trans cooler
- Power Seat Conversion Install
- Is your 3rd gen starter clicking? Quick and easy repair!!!
- What should a Clean MAF sensor look like?
- No more RUNNING BOARDS
- Weak rear de-froster
- best gear oil for 4Runner
- strawberry miilkshake coolant not HG!
- High Pitched whine with first start: Please help
- '04 Taco gas tank "skid"
- #1 Cylinder has rust after HG death
- Decided to get the runner a little airborne & i tweaked the front sub frame. Help??
- ABS Unit Noise/No Start - HELP
- Bent in bumper
- Has anyone changed their own 99 runner LCA bushings?
- 97 Runner Stalled out driving down highway
- U Joint going bad ?
- FTC1 Settings
- Fixed after my insurance incidents, new rear axle....
- Rear break line no fluid
- Thud sound from front suspension
- my 4Runner has low RPMs ??
- Chain Drive T-Case Question
- Towing with your 3rd gen.
- Bilstein Resevoir Shocks
- factory hood scoop can it be used for air intake?
- clicking clutch pedal
- Sparkplug Wire Question, Cracked plastic
- Recurring stut-t-t-t-er HELP!
- SC Install Results
- Tailgate lock replaced now hatch window troubles Help!
- Noise from speedometer, electric or cable? and how to fix
- 99 runner lower control arm update....need opinions
- Outer Tie Rod End issue since freehub swap...
- Strange Noise after lift kit Install
- Grille Guard Width??
- Spotted: 3rd gen silver sport edition in GA
- Drive Belt Replacement
- Flowmaster 40 muffler -exhaust on 3rd gen 4runner????
- baseline map SAFC or SAFC II
- Opinion on whether to buy a 1996 Tacoma
- Seat belt
- Injector duty cycle question
- Rear axle seals blew, replaced, still leaking
- Fuel Injector Replacement Issue
- Limited Bumper Flairs or No Flairs
- 3rd gen lifespan: 300K plus?
- pickin up used 3.4 tomorow
- New pics of the '99
- 5vz tacoma sr5 s/c dyno results
- Tundra Control Arms?
- Need help with 99 runner lower control arm bushing install
- Who's 3rd gen?
- Oil residue around transfer case
- Yet another use for the 4runner tow hitch
- Tundra Brake conversion
- '04 Tacoma V6 4x4 Spindle
- Rear drum brakes and off-roading?
- ADD VSV cost??
- 3.4 5VZ-FE head gasket replacement questions
- Savage Off Road Bumper
- Cracked intake tube, Why?
- Sticking valve(s) on my 3.4: valve job, adjustment, or rebuild?
- Brake Light on after bleeding
- Major Fitment Issue with TJM T-15 ::NEED HELP::
- Gauge cluster swap. CDN --> US ?
- '96 4Runner Bucking under load.... Ideas?
- Inner fender rubber liners
- Rear Squeaking? Any Ideas?
- Drivers windshield wiper won't work...
- 2002 3.4 in 1997 Tacoma
- Failed Smog Test: High NO, already cleaned my MAF, trying to figure out the problem.
- Stock TRD Bilstein suspension
- Rear heater lines
- LED Security Light Flash Rate
- GSGALLANT or others - after market cruise
- AndyMod 2.0. ABS Remains Active.
- Throttle surge when turn signal is on in O/D
- Rear housing plug replacement.
- Junkyard Research: 2002 4runner
- PS Pump Squeaking?
- 96 runner vehicle height
- Tacoma fender replacement
- What is this plug??
- Over Heating/Leak? Need Help Please
- Fouling Plugs
- suspension & ride height...
- grille support bracket broken
- Whining troubleshoot (97 3.4)
- Better than OEM spark plug wires?
- New brakes squeaking!!!
- Couple new additions - new winch and alloys
- Brake Calipers
- Front end noise
- 3.4L Oil Leaks (150k)
- N-Fab detachable steps on 3rd Gen Sliders
- A couple of shots of my Runner from this Summer
- BADLAND front bumper installed
- 3.4 Clutch problem @ higher rpm, searched
- My Home made Safari Rack
- 97 4runner needs ring and pinion?
- Surging under 3200RPM
- Door panel removal - how???
- Under hood light
- ENG Check Light Intermitten
- My New Toy
- Broken Rear lug nut stud. Difficult repair?
- IAC one way valve purpose?
- Clutch pedal starting in 2000 4runner
- OME coil question
- Need some help with ABS
- Possible missing engine components?
- Whos got a Timing belt and water pump replacement write up?
- Trans pops into 2nd gear?
- Manual Transmission question
- 2.7 Low RPM power, and lack of it
- Toyota Emblem on Tailgate
- Tacoma is in rough shape. Possibly EGR?
- 33's--BUT WAIT THERE's MORE
- 4runner with rear diff lock and ABS axle assembly
- any one looking for parts on their 97 runner?
- 1" rear spacer for 2001
- oil leak and egr valve
- Shifter Rattle?
- 2002 Tacoma 4H and 4L won't engage
- rear end swap options for 3rd gen T4
- Tru Cool 4544 Installation Orientation Question
- Mixing Long Life and Super Long Life coolant
- Snow.. and some new pics!
- 96 4runner 3.4l misfires in cylinders#1,#2,&,#3
- Rear Axle/Diff Rebuild, etc.
- Spun a Rod Bearing in my 5VZ
- Tjm t-17 + 2" bl
- 98 4 Runner Ecu --Mods ??
- Bought a '97 SR5
- Headlight Issues after Replacement
- Transmission cooler
- Steering Rack Movement Q
- Rear Moon Roof
- 99 SR5 "Highlander" factory alarm going nuts
- 1st gen supercharger vacuum tubes
- sport hood with hood bra?
- Wiring / purpose "orange box" in the tailgate
- 01 Tacoma automatic transmission clunk
- 01-02 4Runner How to Zero Point Calibrate your VSC system.
- Waterpump difference between transmission types?
- Water forming on passenger side of floor in Tacoma. Any ideas?
- How to install an ARB for dummies
- Cheap no-brainer $15 horn upgrade
- Throttle Body Coolant Leak?
- Blown head Gasket
- 96 Tacoma starting issues...
- 315's on my current setup?
- Finally got an 3rd gen 4runner...
- 96 4runner airbag parts help
- atf additives in power steering?
- 02 TRD Tacoma
- Vortex Cherrybomb
- Bushwacker pocket style flares (96-02 4runners)
- 3' revtek coil lift?
- transmission question?????
- Bumper List
- Help with suspension noise
- Is this my OEM master cylinder? Think I got screwed
- Help with broken rear view mirror
- Floorboard Lighting
- VSC and/or TRAC issues - 01 4runner
- a couple curious questions about my 3rd gen
- pwr Door locks only work with engine running
- Exhaust and bumper recommendations
- Tundra 5100s
- cheap ebay headlights
- Head Gaskets and the 5vzfe
- Lift Issues...
- Brake Problems...
- Projector Lights Mod-Need some basics
- Can you change the idle RPM?
- Cupholder Mod ?'s and other flight 2 ?'s
- help 2000 rear pannel removal & electrical issues
- '97 4Runner LTD IAC?
- HELP! Runner hesitates when intially begining to drive away after a stop!!
- Speedy playing in the snow....
- ARB Tacoma Bull Bar Installed! Pictures!
- 04 Tacoma Extended Cab window linkage
- anyone have this starting problem?
- Valve cover gaskets replaced,now p0325 knock sensor code
- strange idle
- Taking out 3rd gen driver/passenger seat possible?
- Supercharger blow my head gasket?
- knock sensor wire for ECU
- Help B4 I break another differential
- which pinouts for knock sensor wires on ecu
- wheel spacer recommendation
- Better sound out of my muffler
- Tacoma fuel gauge issue
- Castrol import transmission fluid
- 96 Tacoma will not run?
- Pics of my newly custom built 3rd gen Tire Carrier!
- Is it OK to use 16x7 18-hole spare steely's as a full time set of wheels?
- Vehicle Speed Problem
- master cylinder replacement
- 4runner bolt spec question
- Help! can't get cracked radiator out
- Supercharged 5VZ Hard Starting?
- P0120 TPS CEL etc.
- Head Gasket?
- MAINTENANCE question. (timing belt/water pump)
- Driver's door bent forward like in Tommy Boy
- How easily does the SC coupler go on?
- 3.4 Head Gasket Project
- Cali Cats options
- Is my ADD actuator stuck?
- wrong spring rate with OME?
- Oil light and ebrake light stay on when key is out of ignition.
- difference between 234-9001 and 234-9002 Air/fuel sensors?
- Compression Test Results
- New Front Brake Rotors & Pads - Recommendations for '98 Tacoma 4WD
- Anyone used the MaxiTrip (Scangauge II copy)?
- Help, need good shop in CT for TB
- "Hey Corey, where is my thread?"
- Need help in who makes best CV Joints
- a-arm hitting tire.
- something causing rear axle sideways movement
- tacoma temp guage question (2.7)
- Clutch Master replaced, pedal has no travel
- New drawer storage/sub and amp box!
- 2rzfe work in place of a 3rzfe
- Independant Fog lights on 2001
- Updated TSB For O2 Identification
- Exterior rejuvination tips
- some pics of the runner wheelin!!
- '01 Limited w/ ARB Sahara
- what causes my CEL to go on and off at times?
- Unexpected lift issue, resolved
- Climate Control + Radio Lights Question
- Powertrax lockers?
- "clunk" noise on bumps. Help! any ideas
- Rheostat Dimmer Reoccuring Problem - Helpppp!!!
- Please Help! Cylinder #2 Misfire 3.4l
- 95.5 Front Hub and Bearing Removal HELP!
- 7th Injector year differences?
- weird clunkingO noise from the back?
- part # for tall 99 runner springs
- cheap off road driving lights question
- Transmission Leak?
