4runner with rear diff lock and ABS axle assembly
Old Feb 9, 2010 | 01:12 PM
Noil's Avatar
I have a 97 4 Runner Limited with rear diff lock and ABS, and need to replace the rear axle assembly, however this has presented an issue I have not been able to find a replacement assembly with the rear diff lock and ABS.
Is it possible to modify a rear axle assembly without diff lock and with ABS? If it is possible what would I need to do? If not what are my options to replacing the axle assembly?
Old Feb 9, 2010 | 01:16 PM
vital22re's Avatar
totally a bro
contact deathcougar. He knows whats up.
Old Feb 9, 2010 | 02:38 PM
brian2sun's Avatar
There's lots of info on elocker retro-fits into non-elocker axles, a search will give you more info than you know what to do with because it's one of the most heavily covered subjects on here and every other Toyota forum. Why an entire axle assembly, what exactly is broken on yours?
Old Feb 9, 2010 | 03:35 PM
crolison's Avatar
you can retrofit and 8" housing for an elocker, abs or not.
im dumping my elocker next week, replacing the housing and getting detroit
Old Feb 9, 2010 | 04:33 PM
Noil's Avatar
Thanks for the replies ... my 4 Runner was involved in a roll over; the rear end afterwards has leaked grease out on the the rear brakes causing the ABS dash light to stay on and there is a loud grounding and slight wobble when it is driven regardless of speed.
Does this sound like the assembly could be salvaged?
Old Feb 10, 2010 | 05:10 AM
crolison's Avatar
to be safe i'd go ahead and get a whole new assemble, it will make things easier with your problems.
I think mine is bent, i got t-boned and it fubar'd a good amount of stuff
Old Feb 11, 2010 | 03:26 PM
Noil's Avatar
Thanks for the input Crolison, still looking into local options. I have found one but it is in Colorado, I am confident that between my mechanic friend and myself we will be able to adapt something either from a 4 runner or a Tacoma with a TRD package. At least to my understanding the axle assembly from a Tacoma TRD can be adapted.
Old Feb 14, 2010 | 06:13 AM
jackpot's Avatar
Rear Axel Assembly
I have a 2000 4runner limited hub to hub rear axel assembley that I was going to replace on my 97runner before I totaled it. Anyone interested ?
Old Feb 17, 2010 | 06:05 PM
Noil's Avatar
I have finally found a rear end going to go pick it up on the weekend! Thanks for all the info and offer.
Old Feb 17, 2010 | 08:40 PM
brian2sun's Avatar
What did you get? elocker?
Old Feb 18, 2010 | 08:21 AM
Noil's Avatar
Yeah ... our contact at the salvage yard had a 98 4 Runner with an e-locker come in so it will be replacing what I got keeping it stock. Just glad we found one local.
Old Feb 18, 2010 | 08:46 AM
brian2sun's Avatar
Cool.
Team420
Jan 12, 2021 04:57 PM
merc1100sc
Jun 26, 2015 05:24 PM
AustinTaco
Jun 21, 2015 09:54 AM
Luke
Jun 10, 2002 10:07 AM
